Water Hose Storage
ljpel
Does anyone have any good ideas of how to store your water hose? We have always put it in a clean garbage bag, but I would like something that is clean and can be sealed that is dedicated just to our hoses. We have tried various size plastic boxes, but there is always too much wasted space in them to make them worthwhile.
42 REPLIES 42
Campfire_Time
bukhrn wrote:
Trackrig wrote:
Your profile is incomplete in that it doesn't tell us what your RV is so that people can offer suggestions.
I just screw the two ends together so that nothing gets into the hose and then throw it into a compartment next to all of the hook-ups. If I'm not going to use the MH for a while, I'll put a few drops of Clorox in the hose and shake it some before I screw the ends together.
Bill
X-2 or X-10
X-what ever :B And it goes in with all the other junk in my outside storage. Never been in an issue.
Chuck D.
โ€œAdventure is just bad planning.โ€ - Roald Amundsen
2013 Jayco X20E Hybrid
2016 Chevy Silverado Crew Cab Z71 LTZ2
2008 GMC Sierra SLE1 Crew Cab Z71 (traded)
Lauren
Yup to the above.
Except I got tired of fighting kinking hoses that take up a lot of room and got one of those expanding hoses. Tried one of those small green coil ones once and that did not work - but I bring it with in case the 25 foot is not long enuf - by keeping it with I have never needed it; as soon as I leave it home I would need it on the first stop! ๐Ÿ™‚
We are about to head out for 10 weeks so will see what the expanding one will do. Keeping the big one (25') handy for this trip though.
Barbara-DW 55 years
Sadie-"Aussie" Terrier
06 Mobile Suites 32TK3
06 Chev 3500 4x4 Dmax
20 yrs PT RVing - 190 RV parks; some many times
bukhrn
Bill
X-2 or X-10
2007 Forester 2941DS
2014 Ford Focus
Zamboni, Long Haired Mini Dachshund
Bumpyroad
the nicest/handiest I used was a large bowl that had a hole in the side towards the bottom. feed out enough to hook to RV and then just uncoil what you need off the top of the coil. had a similar cranked one for a standard garden hose.
bumpy
the_bear_II
X 4 or 5... (I lost count) screw together and throw it in a compartment...
beemerphile1
I toss it in the compartment with hoses, leveling blocks, tools and everything else used outside the RV. I coil it and connect the ends to keep out bugs/dirt.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
NanciL
After fighting with 50 footers for many years, I finally smartened up a few years ago and now keep four 25 footers. I coil them up separately and screw the male end to the female end. Then I use short elastic bungees, (the type with a small plastic ball on each end) to keep them securely coiled (three per hose coil). then I just store them in one of my outside under floor compartments.
Jack L
Jack & Nanci
tvman44
I use a plastic tote with a lid, & screw the ends together & put in there with the regulator, extra hose and washers, ect. ๐Ÿ™‚
Papa Bob
Husky 16K hitch, Tekonsha P3,
NanciL
Jack L
Jack & Nanci
rwbradley
I use giant Ziplock bags. Google "Ziplock Oversized non-food storage products". They have a whole line of them going right up to garbage bag sized. They are perfect for the hoses, they do not take up much space compared to bin's and keep any residual water from the hose or dirt from the campground from getting all over the storage area. I also keep my spare sewage extension (which does not fit in the bumper) in one as well.
Rob
rvtechwithrvrob.com
DutchmenSport
Screw the ends together and just toss it in the storage area. I am now using a plastic tote (without a lid), just to keep them organized a little better. I still connect the ends.
riggsp
I use a square plastic bucket that cat litter comes in (cleaned it out of course)...the lid snaps in place and seals easily and it isn't as big as one of the plastic tubs...I coil the hose into the bucket, then screw the two ends together to avoid any contamination (dirt, etc.)...I also drilled some 1/4 in. holes in the lid to let it breathe, otherwise it gets moldy caused by temp. swings and moisture.
Trackrig
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
