Water leaking inside RV from furnace.
MetalGator
I have had two hours of driving rain today. I noticed some water pooling on the floor underneath a cabinet near the fridge. I pulled the lower drawer out and I saw a puddle of water underneath the metal box of the furnace. Water was dripping from the bottom of the furnace. Has anyone ever had this happen before? Could water be coming from the outside furnace vent? This has happened once before but I didn't know where the water was coming from. Both times the rain was pelting the passenger side of the motorhome where the outside furnace vent is located.
Burch
2018 Miramar 35.3 Motorhome
3 fur kids (Monty, ZuZu and Pinto)
Rainbow bridge (Murphy, Petie, Lola)
6 REPLIES 6
MetalGator
The furnace is underneath the fridge. We have a residential frig and I don't see any vent on the roof. When I had our TT, we had a absorption fridge that did have a vent. Everything I have read is the vent tube should have a 45 degree angle up so water doesn't get inside the furnace. My tube angels down. This has happened twice now and both times I had a heavy sheeting rain against the side of the motorhome that the furnace is on. The first time I couldn't figure out where it was coming from. This time, I pulled out the bottom drawer that is near the floor next to the fridge. I could see water dripping from the bottom of the furnace near a screw that holds the bottom sheet metal of the furnace. There was no water running on top of the furnace under the fridge. As you can see in the picture above, the vent tube angles down so any water blowing in the vent hole is going to drain into the furnace.
Dennis12
Had the exact same issue. Drove me nuts until i found it .The hinge on the left side of my furnace door was leaking. Make sure that everything is dry in the furnace compartment. Close the door. Run water slow from the top of the door. Not much. I seen water laying in a trough and going in along the left hinge. chalked it and problem solved.
Dennis Hoppert
wa8yxm
I agree the source of water is likely one of two things
1: the Friges Ice maker .. the line splits and sprays water all over everywhere
2: The Defrost Drip Tube or if you please just Drift Tube
on No-Colds it goes into a "Evaporation Cup" and usually no problem
On Domnetics it is SUPPOSED to be poked trhrough one of the vent holes in the outer cover so it drip-drip-drips on the ground.
A 3rdm related source (Same as last) is the fridge itself. if for some reason the water is NOT going into the drip tray and tube.
doxiemom11
Is the refrigerator sitting above the furnace inside? Ours does and we had a leak that was coming in fr om the roof vent for the refrigerator. Water was all over under the furnace. Outside compartment flooded and then water leaked inside and pooled under the furnace.
MetalGator
Now that it stopped raining, I went outside and unscrewed the panel where the vent is. This doesn't look right? Shouldn't the vent pipe be turned the other way so water can't get in? The angle goes down instead of up?!?!?
midnightsadie
sounds like it just blue in the outside pipe.
