โNov-19-2014 11:29 AM
โNov-20-2014 01:54 PM
โNov-20-2014 01:42 PM
โNov-20-2014 12:54 PM
โNov-20-2014 08:14 AM
โNov-20-2014 07:22 AM
Bud
USAF Retired
Pace Arrow
โNov-20-2014 06:13 AM
Duck wrote:myredracer wrote:rockylarson wrote:
I use the Watts pressure regulator set at 60 and the Oxygenics shower head. More than adaquate.
Watts Pressure Regulator
Much cheaper at RVwaterfilterstore.com - $64.95 Excellent service from this place too. (Amazon can be a ripoff sometimes.)
X2 Water Filter Store has a lot of information also.
Don
โNov-20-2014 04:40 AM
โNov-20-2014 02:38 AM
โNov-20-2014 12:57 AM
An exterior mounted inline "regulator" is not really a regulator and is simply a flow restrictor. They only have a very small dia. hole inside them, nothing else. It will reduce pressure when there is a flow, but when there is zero flow, the pressure will equalize on both sides of it and you can end up with excessive pressure in your system.
A real regulator is a much better choice like the Watts H560 mentioned above. Even better for a few more $$ is the Watts 263A with about twice the flow rate of the H560 and is what we have. I have ours set to 60 psi.
You are better off always using a regulator. The pressure in a CG can vary a lot from night to day and can go up quite a bit during the night. I have a tell-tale gauge ahead of our regulator and the highest pressure it recorded for the season was 100 psi and I have no idea when or where. I've read some saying pressure can reach close to 200 psi. Best to use good protection 100% of the time.
โNov-19-2014 07:51 PM
โNov-19-2014 02:28 PM
โNov-19-2014 01:51 PM
โNov-19-2014 12:57 PM
โNov-19-2014 12:53 PM
