water pressure regulator
4aSong
when connected to city water and using our water pressure regulator we notice that each time you turn the water faucet on that the flow starts slow then increases, is this normal?
M & N
Tundra TRD V8 4x4 w/Leer Shell
EU2000i * Prodigy * McKesh * Trek * Renogy * ENU
10 REPLIES 10
wa8yxm
Did you type that backwards?(You said Starts slow then increases)
Im used to Starts fast then decreases
Water regulators come in several types
3/4 inch cylinder (About) no fancy grip on female end: JUNK
3/4 inch cylinder (About) w/ fancy grip on female end of wings.. JUNK
The one pictured above: Minimum I would consider, but I think it's a tad small
Sur-Flo (This is the one often factory installed) Minimum I would consdier
Watts, Zurin or other make at least 1/2 inch (Mine are 3/4) with hose adapters
EXCELLENT
Valterra adjustable: I have not tested but others are happy with it.
GoPackGo
downtheroad wrote:
Sfla2 wrote:
downtheroad wrote:
I have this...never experienced what you are describing.
Does it happen at different campgrounds or just one?
what kind is this &where did u get it
Got it from this outfit. The guy is a full time RVer. Sells them on the side and he know his stuff when it comes to regulators and water filters.
RV Water Filter Store....HERE
That guy is great. I wrote him a long email once and got a prompt, in-depth reply. He sells pressure regulators, water filters, many different kinds of filter elements and also quality hose in several lengths. You can get quite an education by visiting his site and reading what he has to say.
I am very surprised at the number of CGs that have high water pressure. I have the one in the picture and set it to 60 pounds.
Tim
downtheroad
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
Dakzuki
old guy wrote:
you can buy them at the big box stores. spendy but worth every penny
Available on line too.
2011 Itasca Navion 24J
2000 Chev Tracker Toad
old_guy
Sfla2
98 Coachmen "C" Santara Model FL (Front Lounge) 30.4
Ford V 10 Super Duty (same as E 450)
coolbreeze01
Good idea to turn the water off while you are away. Have fun........
2014 Sandsport 26FBSL
NMDriver
I would say that while not "normal" for a pressure regulator it may not be a problem for your particular brand. As long as the pressure stays below the 50-60lbs recommended for RV water lines I would not worry about it.
What kind of regulator are you using? My Watts whole house keeps a constant pressure and flow rate.
Have you cleaned out the debris screens on your faucets lately? It may not be the regulator but the faucet.
5er/2500Duramax/18ftBoat
Bumpyroad
Do you have a decent watts type or a $9.00walmart special
downtheroad
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
