Water System
cwobosn
Still trying to get the valve settings right. There are no instructions on mine as there are on the 13s. My valves read: FW IN @ 12 o'clock & pump @ 3 o'clock then FW OUT @12 o'clock & pump @ 3 o'clock "knob turns right...
Artie & Karen
2008 F-350 Lariat, diesel, cc, drw.
2010 Landmark Augusta
3 REPLIES 3
lanerd
A picture is worth a thousand words. With out any, your description is open to interpretation. However, I go with what Matt said.
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
Matt_Colie
SCH is probably right about the low point drains. Get them shut. They are probably inside.
You are not very clear about the others, but it sounds like you have two each two position valves so there is not an "ON" and "OFF". One valve selects to fill your tank from the city connection or the tank to the pump suction (in), and the other selects your system source as from the pump or the city water connection.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
sch911
The two drains under the camper are called low point drains. They are typically opened for winterizing, and most likely have their own valves. Follow those two lines up into the camper to find the shut off valves.
OEM Auto Engineer- Embedded Software Team
