โJan-12-2018 06:51 AM
โJan-28-2018 01:31 PM
โJan-21-2018 07:12 AM
โJan-21-2018 06:44 AM
โJan-21-2018 05:47 AM
โJan-20-2018 05:20 AM
โJan-19-2018 09:20 PM
โJan-19-2018 05:52 PM
โJan-16-2018 06:43 AM
โJan-16-2018 06:32 AM
โJan-16-2018 05:56 AM
โJan-15-2018 11:45 PM
โJan-15-2018 05:38 PM
drsteve wrote:
You will feel passing trucks tug at you even with a perfect setup. As long as no sway is induced, it's all good.
Try to get the trailer to set level or slightly nose down.
It sounds like your tongue is light. The WD hitch will not compensate for that.
You are correct that the head angle seems to be too upright.
You shouldn't be pulling faster than 65 anyway, but the trailer should not sway, even if you do.
A trip to the scales may be in order to eliminate the guesswork.
โJan-15-2018 05:08 PM
โJan-15-2018 04:37 PM
