โOct-04-2017 06:43 PM
โOct-07-2017 09:06 PM
Flyfisher410 wrote:
GCVWR is 13500. GVWR for the tow vehicle is 7350. Weighed in on CAT scales today and was 710 pounds over on the drive axle but 390 below max on the front axle. Trailer weighed in at 6200, each trailer axle is rated at 4000 pounds, dry weight is 6060 with additional cargo capacity of 1200 and change.
Will adjustment to the weight distribution hitch transfer extra weight off the rear axle?
โOct-06-2017 04:34 AM
Flyfisher410 wrote:
ehoefler, the tongue weight of the trailer was listed as 788 pounds, I had the dealership install a second battery which they did on the tongue. The hitch is a Husky centerline with 800-1200 pound rating. Dealership installed the hitch when we picked up the camper so it had nothing in it when installed. Now that its loaded I think I need to adjust the brackets for the bars as the rear of the vehicle squats a bit, but I don't know if that is enough to remove the excess weight from the rear axle.
โOct-05-2017 04:49 AM
โOct-05-2017 03:56 AM
โOct-05-2017 03:02 AM
โOct-04-2017 09:31 PM
โOct-04-2017 08:13 PM
โOct-04-2017 07:50 PM
โOct-04-2017 07:43 PM
โOct-04-2017 07:36 PM
โOct-04-2017 07:09 PM
โOct-04-2017 07:01 PM
