Mar-26-2020 05:36 PM
Mar-31-2020 01:27 AM
Mar-30-2020 09:30 PM
Mar-30-2020 05:34 AM
cpaulsen wrote:
Thought a GFI to start with. Onle one we have is in the bathroom...all other outlets are kinda like daisy-changed to the one and only GFI. And no power at the first2 double beakers in the panel. Have checked all connections so far. All worked in the morning before we left one rv park and got to another one and then the problem appeared. Guess I should pull every outlet and check the wires since the GFI will not reset.
Do you mean " no power " on the wire terminal of the dbl pole breaker ?
When resetting GFI make sure all outlets on that circuit have nothing plugged in. If it still doesn't reset then gfi either bad or you have a bad wire and it's doing its job. Normally the gfi only protects the bath/kitchen/ outside plugs
Mar-30-2020 03:57 AM
Mar-29-2020 06:06 PM
Mar-29-2020 05:40 PM
The GFI needs to have power to it, in order to be able to be reset it.
Yes it does and my power worked for 2 days and now the same problem with the GFI again....no power to the front of the 5th wheel!!
Mar-28-2020 04:00 AM
Mar-28-2020 03:53 AM
Mar-27-2020 03:45 PM
Mar-27-2020 07:58 AM
Mar-27-2020 05:50 AM
Mar-27-2020 05:42 AM
cpaulsen wrote:
And no power at the first2 double beakers in the panel.......All worked in the morning before we left one rv park and got to another one and then the problem appeared.
Mar-27-2020 05:00 AM
Mar-27-2020 04:13 AM
