โMay-31-2015 07:57 PM
โJun-01-2015 05:51 PM
rileybrake wrote:
K so the grounds have nothing to do with the 110v inside the trailer?
โJun-01-2015 03:22 PM
โJun-01-2015 01:51 PM
โJun-01-2015 11:03 AM
โJun-01-2015 11:02 AM
โJun-01-2015 10:42 AM
โJun-01-2015 10:12 AM
rileybrake wrote:You are checking the wrong wires - everything you mention is your 12 volt system.
Anybody know of any other ground locations on that trailer or possibly a wiring diagram(kind of a long shot I know) I checked and cleaned the ones in the battery compartment, the front compartment, inside the plug-in compartment and one underneath the trailer toward the back. I may be able to contact the manufacturer for one but i fear that because its so old and they're not even in business anymore that ill be out of luck.
โJun-01-2015 07:22 AM
โJun-01-2015 06:00 AM
โJun-01-2015 05:52 AM
โJun-01-2015 05:19 AM
โMay-31-2015 10:27 PM
kaydeejay wrote:Houston Remodeler wrote:I agree, but based on your observation of 110V from hot to ground, but only 8V from hot to neutral I would suspect an open neutral, maybe even as far back as the panel.
You have a loose connection.
Start there and check your connections for tightness and lack of corrosion.
โMay-31-2015 09:14 PM
โMay-31-2015 09:07 PM
โMay-31-2015 08:33 PM
