Jun-15-2016 09:57 PM
Jun-20-2016 09:21 PM
Jun-20-2016 08:27 PM
Jun-20-2016 08:02 PM
Jun-20-2016 03:02 PM
mlts22 wrote:I would use a sine wave inverter to power the brick if the thing is that fussy.
Apologies. I've not been much on the forums in a bit, due to work stuff. The device is a Synology DS216+ NAS, which uses 12 volts to power it. Too little or too much, it gets unhappy.
Jun-20-2016 02:37 PM
Jun-20-2016 02:21 PM
Jun-20-2016 02:01 PM
Jun-20-2016 01:50 PM
Jun-20-2016 01:35 PM
Jun-18-2016 12:08 PM
Jun-18-2016 11:47 AM
Jun-18-2016 11:26 AM
Jun-16-2016 01:06 PM
Chris Bryant wrote:
{subject change}subcamper wrote:
DC-DC Converter 10-18VDC in 12VDC out
That's a great site- particularly http://www.powerstream.com/powerhumor.htm
{/subject change}
Jun-16-2016 12:53 PM
Sam Spade wrote:And this makes you #5 🙂MrWizard wrote:
And either one will run directly off the RV 12v systems , no power conversion needed, no damage done
And here's about the 4th person asking what this device IS.....because I think you are mis-interpreting something and causing yourself undue worry and expense.
I've been in Electronics for about 50 years now and have yet to see ANY device that requires an exact input voltage to work right.
