โJul-06-2013 05:51 PM
โAug-17-2013 07:36 PM
โAug-17-2013 05:24 PM
โAug-17-2013 02:08 PM
MEXICOWANDERER wrote:
I PLUG INTO ONE OF THESE
โJul-09-2013 08:45 PM
โJul-09-2013 06:43 PM
โJul-09-2013 06:27 PM
โJul-09-2013 02:43 AM
camperpaul wrote:
If you are using a 12 Volt TV set, you don't need the inverter.
โJul-07-2013 06:32 PM
Almot wrote:There's one for genny/shore power but I did not add another one. Don't need too.
no transfer switch?
BFL13 wrote:X2, my Go Power 300W PSW inverter will do the whole 300W from one receptacle.
The two cords thing might be where each receptacle only does half the rated watts of the inverter. One inverter model has 1000w rating but each receptacle has a limit of 500w eg.
Many inverters will do the whole thing from one receptacle, but you have to read their manuals on-line to make sure, and even then IMO phone their tech support and try to pin them down on that topic, to be even more sure before buying that model.
โJul-07-2013 04:38 PM
mustangglp wrote:
Thanks for all the help
I hardwired the inverter with 8 gauge wire with a 36 inch of wire run it seams to work if i run two cords it won't work if I run one! The hard drive and the satellite receiver must take quite a bit of power they don't seem to have any UL power specifications but they do put out a lot heat.
I guess I need to think about a bigger inverter If I do that I will want more solar panels. and a dedicated stating battery for the generator.
โJul-07-2013 04:03 PM
mustangglp wrote:Simplygib wrote:
While boondocking I have the inverter connected to the batteries with 10 ga. wire. My rig's 120v power cord is plugged in to the inverter. That way all my 120v outlets are live and I can plug in the (in my case, laptop) anywhere I want. If you go this route you will want to make sure your converter is disconnected first, and don't try to run stuff like microwaves, a/c, hair dryers or welders (;)) on it.
So how do you go about disconnecting the converter:h that would be sweet
the only downfall I can see would be having to go outside and switch the plug to run the generator. I could mount the inverter in the generator compartment right next to the batteries?
โJul-07-2013 12:13 PM
โJul-07-2013 04:45 AM
โJul-07-2013 01:36 AM
mena661 wrote:
I put a 30 amp receptacle in my MH's shore cord compartment. From there it goes to a 20 amp plug. The plug goes to a 300W PSW inverter. The inverter is hard wired to my batteries. All I have to do is turn my converter off. My converter and inverter are in the same compartment so I just unplug the converter and turn on the inverter.
โJul-06-2013 10:40 PM
mustangglp wrote:Yes get it close as you can to the batteries. I just unplug my converter. When I had a 5th wheel the converter shared a breaker with the outlets. I moved it to its own breaker but my MH already had it on a separate breaker. Some people put an on/off switch on the converters 120V line.
