โSep-16-2017 06:29 PM
โSep-19-2017 04:23 PM
noteven wrote:15/20/30 amp are all the same electrically, just able to provide different currents. 15 to 30 "dogbone", and a 30 amp protector won't know the difference and will work just fine.
I don't see how you check a 15 amp plug in with one of those ?
โSep-19-2017 03:37 PM
Dave H M wrote:
I was thinking the same thing as sig and drew.
Something don't add up here in my foggy cranial area. :h
โSep-19-2017 03:34 PM
SoundGuy wrote:SoundGuy wrote:
If the OP really wants to learn from this experience he'd invest ASAP in a Progressive Industries EMS w/Surge Protection, portable or hardwire, that will constantly monitor incoming source power, refuse to pass faulty power on to his trailer whenever any such error may occur, AND tell him the reason why it won't do so. :B
OR like many he could ignore this advice, potentially risk his life AND his trailer's electrical system, and hope he never runs into any situation ever again where the power source being supplied isn't what it should be ... yeah, what are the chances?! :Rnoteven wrote:
It's unclear as to what your "?" means but surely as a forum member since 2011 you'd have to be well aware of the Progressive Industries series of EMS units that will easily prevent situations such as you've described, protect you at the very least from a nasty shock, and could under some circumstances, potentially save your life. No? :@
โSep-19-2017 05:31 AM
โSep-19-2017 05:23 AM
noteven wrote:
โSep-18-2017 09:59 PM
DrewE wrote:
Even with reversed polarity, you should not have 120V on the RV chassis unless the ground wire from the receptacle was also reversed and wired to the hot (at, say, the main electric panel). Having that sort of stray voltage indicates at the very least poor grounding, and quite possibly also a neutral to ground fault in the RV. I would guess that if you plugged the RV into a GFCI protected receptacle the GFCI would pop due to a ground fault.
โSep-18-2017 09:42 PM
โSep-18-2017 07:29 PM
โSep-18-2017 07:17 PM
SoundGuy wrote:noteven wrote:
Issue resolved - power supply recepticle the trailer was plugged in to had reversed polarity. Fixed.beemerphile1 wrote:
Learn from this, your life depends on it; never connect to any pedestal without first checking the polarity and voltage.
โSep-18-2017 08:49 AM
โSep-18-2017 07:12 AM
noteven wrote:
Neither on board generator or a portable supplying power to the shore power connection have the same issue.
Indications are the polarity of the shore recepticle the trailer was connected to is reversed. Electrician being consulted.
โSep-18-2017 05:07 AM
โSep-18-2017 04:44 AM
โSep-17-2017 10:01 AM
