2012 Keystone Avalanche 330re keyless entry problem
jmnoeth
I have a 2012 Keystone Avalanche 330re that has a keyless entry system (southco r03). I had to replace the keypad on the outside, but, the receiver is still paired with the old keypad. I found the directions on the Southco website on how to pair the receiver and keypad, but, that requires access to the receiver. So, my question is where is the receiver? My guess is that it is in the core of the door. But, didn't want to start taking it apart until I knew that's where it is.
2 REPLIES 2
jmnoeth
Thanks, Doug. I do have the spring loaded pins, but it appears that those pins have a constant 12V across them. That's what leads me to believe its in the door somewhere. I'll try taking the window out to see if it's in there.
dougrainer
On Jayco products that used that system, the controller was inside the entry door. You removed the window in the door and the controller was located in the cavity below the window. IF you do NOT have the spring loaded pins in the door frame on the hinge side, the controller will be inside the door. IF you have those 2 spring loaded pins in the door frame on the hinge side, then the controller will be inside the RV somewhere. Doug
