Apr-27-2018 04:38 PM
Apr-28-2018 01:32 PM
joebedford wrote:
Question about my generator but it's pertinent to the thread: I have a 5500W generator 120/240V that I use for house backup.
Other than pulling the darn thing apart, is there any way to tell which leg/winding the 120V plugs are on?
I assume the 40A twist lock plug has one pin on one winding and the other on the other so to speak. Not sure about the 120V receptacles though, which I think is the question OP is asking too.
Documentation (hahaha) doesn't say.
Apr-28-2018 10:28 AM
Apr-28-2018 10:21 AM
time2roll wrote:
Is that a GP8000E? Comes with a four prong 30 amp 120/240v service and a few standard home outlets.
That 3 prong adapter will not work. Or generator is something else. Need 240v connector to get 8000 watts out of a generator on 30 amps.
https://www.northerntool.com/shop/toolsGP8000E
Apr-28-2018 08:33 AM
Apr-28-2018 08:29 AM
Apr-28-2018 06:46 AM
Apr-27-2018 10:18 PM
time2roll wrote:
Yes you can get an adapter but will be pulling from just half the generator. So it becomes 4000 watts and is plenty for a 30 amp RV. Not sure how the mining equipment fits into this. Probably two of the 5-15 outlets come off each side so if you need 120v you are in good shape. A 240v dewatering pump may require the RV to be unplugged or go to low power outlet.
3500w Champion with RV plug
L14-30 to RV30-TT adapter:
https://www.walmart.com/ip/AC-Connectors-RVL1430TT-Generator-4Prong-L14-30P-30Amp-Locking-Plug-to-RV...
Apr-27-2018 10:02 PM
Apr-27-2018 09:48 PM
Apr-27-2018 07:18 PM
ktmrfs wrote:
The big question is why didn't the RV industry standarize on the 30A twist lock?
Apr-27-2018 06:56 PM
Apr-27-2018 06:06 PM
Apr-27-2018 05:36 PM
Dutch_12078 wrote:
Are you referring to the Marinco style twist-lock socket commonly used at the trailer end of the cord versus the TT-30 plug used at the shorepower end? You should only need an adapter for the TT-30 plug to the generator outlet, and that's not very costly.
Generator Plug Adapter for RV Power Cord-30 Amps-3 Prong Twist Lock
