50FT CAMCO HTD HOSE
nieforth
50 FT CAMCO HEATED WATER HOSE. Hose plugged in power light on....should i feel any heat at all from the hose either along its run or at the connecting ends?
THANKS
5 REPLIES 5
nieforth
Thanks for your time in replying:
HAPPY NEW YEAR
cpaulsen
On my Camco heated hose...you can run your hand anywhere along te hoe and feel the warmth.
cpaulsen
Mike_LeClair
We use a 25ft PIRIT heated hose, controlled by a built in t-stat. I have felt the hose from time to time and have never, ever noted it to feel even remotely warm to the touch. It does work very well though as we just went through some pretty chilly -18*C nights with no problems / frozen water lines.
Cheers!
Mike
Something Old, Something New
2012 F350 SRW, 6.7l Powerstroke, 3.55's front and rear.
2008 Fleetwood Regal 325RKTS
Mike, Carol and our 4 legged "furry child" Kenzie Shweenie Tod
nineoaks2004
I do not own one, but it should at least feel warm..unless it has a thermostat built in (my opinion)
Our heaters for the stock tanks just warm the water and has a thermostat so they do not turn on until the water gets cold.
By the time you learn the rules of life
You're to old to play the game
1492
Moderator
Moderator
Moved from Forum Technical Support
