โMar-26-2017 08:55 AM
70 Amp RV Converter/Charger
The PD9270C-14.8, 70-amp power converter is designed to provide reliable filtered DC power for batteries that require a higher boost/bulk voltage such as Trojan and others. The PD9270C-14.8 converter also provides safe and rapid recharging of RV batteries. Built-in features such as electronic current limiting, reverse battery protection, high voltage protection, low voltage operation, and over temperature shut down ensure long-term reliability. The built-in Charge Wizard is a microprocessor-controlled system that constantly monitors the battery voltage and ensures a rapid; yet, safe, recharge. The Charge Wizard can select one of three charging voltages and one of four operating modes depending on the condition and use of the battery.
Features:
Built-in Charge Wizard
Reverse Battery Protection
Delivers filtered DC power to all 12 Volt lighting and appliance circuits, providing safe and reliable service
Electronic Current Limiting
Low line Voltage Protection
Variable speed intelligent Cooling Fan
High Voltage Protection
Automatic thermal shutdown
Built-in accessory port for the Converter Status Remote Pendant
2 year limited warranty
Input: 105-130 VAC, 1250 Watts
Output: 13.6 VDC, 70 Amps
Dimensions: 3.6" X 8 X 9
Weight: 5.8 lbs.
โMar-27-2017 09:20 AM
westend wrote:
Forum member Dave/Sparky did applied voltage tests with many common LED replacements. He found all would endure at least 15V. I think you're going after a problem that may not exist.
FWIW, my LED SMD panels may see 14.8V on many days in the Winter when the temp compensated solar is pushing higher voltages. I haven't lost a one.
โMar-27-2017 07:05 AM
โMar-26-2017 07:12 PM
MrWizard wrote:
I used LED strip lighting cut from a 5 meter roll
These are routinely exposed to applied voltage up to 14.8v
Almost 2 years use , the kitchen sink one, is almost always on
I lost one LED, in one strip
All light fixtures have multiple strips
โMar-26-2017 06:37 PM
โMar-26-2017 05:22 PM
โMar-26-2017 05:01 PM
DiskDoctr wrote:
My electronics buddy with a scope is out of town for a while. I will likely be at least 2 weeks before we can get together. Hoping someone here can help?
โMar-26-2017 04:27 PM
BFL13 wrote:
What is the scenario for having the LEDs on when your 12v system is at 14.8 ?????
โMar-26-2017 04:19 PM
โMar-26-2017 03:55 PM
HQ 80A Solid State Relay SSR AC-AC Input 70-280V AC Load 240-480V ?AC A4880
Condition: Brand new
Load Current: 80A
Load Voltage: 240-480V ?AC
Control Voltage: 70-280V AC
Control Current: AC ? 12mA
On-off Time: ?10mS
Dielectric Strength: 2500VAC
Insulation Resistance : 1000M ohm/500VDC
Ambient Temperature.: -30??75?
Working indicators: LED
Size: 58 x 45 x 32mm
Certification: CE
Qty: 1 x Relay
โMar-26-2017 03:18 PM
ktmrfs wrote:
...Now bump the voltage to 14.8V or more agrivates the problem tremendously. Either they are dim at 12V or have premature life at 14.6V.
โMar-26-2017 03:14 PM
SoundGuy wrote:DiskDoctr wrote:
1. Is the 8955AN a FILTERED DC? In other words, can it work properly WITHOUT a battery connected, as the upgraded options all claim?
Yes, the WFCO 8955 doesn't need a battery to "buffer, or regulate, or filter" it's output ... in fact, I'm running mine right at this very moment, battery is still in my workshop as I haven't yet gotten around to installing it on the tongue.
That said, your plan seems more complicated than it needs to be. I'd just mount the new converter in the front pass through cargo compartment, wire it to the nearby batteries, run 120 vac to power it, and just turn the WFCO off and leave it off.
โMar-26-2017 03:13 PM
โMar-26-2017 02:43 PM
โMar-26-2017 02:38 PM
DiskDoctr wrote:
My circuit is pretty simple.
1. Replace SPST On-Off switch in double light (call Side A and Side B) with SPDT On-Off-On switch. Side A is connected to '1' Side B is connected to '2'
2. Connect Side A and Side B through a diode to make it one way circuit that only passes current from B to A.
3. Connect 12v line in to switch pole, bond all negatives together.
Now switch in middle if off.
Switch in position 1 is Side A only (diode prevents power going backwards into Side B)
Switch in position 2 is Side A & B (diode passes power from Side B to also power Side A)
Simple ๐
