Accidental Arc Welder
sjturbo
I needed to check lug size on my shunt today to complete some charging cables. I turned off shore power, and turned off batt. disconnect. While wrenching the shunt bolt off and the wrench slipped and shorted the pos side of the inverter 100A fuse (which I had removed the plastic safety cover from)to the ground lug, and created my own arch welder. I bet most of you have a disconnect between the batt. and the inverter? I will very soon!! I thought it had taken out my inverter and Victron monitor. But fortunately the only casuality was my ego, and the 100A fuse! Oh, and a slight divot in the wrench.
15 REPLIES 15
NinerBikes
msiminoff wrote:
Yes, unfortunately the "wrench-battery-arc-welder-syndrome" is an all too common occurrence. When I was a kid I worked at a hot-rod shop and one of the other mechanics there dropped a wrench which shorted between a pos. battery terminal and the vehicle's frame. The wrench welded itself in place and glowed orange before he was able to grab another tool to knock it off. It scared the heck out himโ€ฆ and me too!
To prevent this I have battery disconnects and have also installed fuses directly to each of my (+) battery terminals.
As an additional (and inexpensive) preventive measure when working on my electrical system, I always wrap the handles of my open end wrenches (and/or screwdrivers) with Rescue Tape.
Glad to hear that the only damage was to your ego ๐Ÿ˜‰
Cheers
-Mark
Putting that on there, now you have 3x the amount of hot contact surfaces on the positive side to bump against ground. I'd put the disconnect on the ground wire, myself, so that the whole frame and all other metal parts are not hot, if by chance you touch the positive against anything grounded.
Bill_T
Guys remember to remove any finger rings before working on your electrical systems.
I wish I could find the pic of my buddy's finger when he grounded a wrench while working on his 24 volt jeep. Not a pretty sight.
Bill and Debbie
2007.5 SILVERADO HD DA CREWCAB LTZ 4X4 ARE CAP
2003 Nash 25S TT
2012 Lance 855S
1996 Coleman Taos pop-up
1970 jeepster,v-6
Snowman9000
wa8yxm wrote:
Did something like that to one of my Inverter fuses.. SIXTY BUCKS (ouch).
T-Fuses are expensive.
Not sure which one you are referring to...
Anyway, the one I showed is about $37 for the holder and the fuse. Extra fuses are about $12. Shipping included in both prices.
Currently RV-less but not done yet.
wa8yxm
Snowman9000
I had one of these on my last RV. The batteries were in a real hard place to get to. I think I'm going to put on my current MH too. The hole in the plate is 3/8", and the stud is 5/16, IIRC.
https://www.bluesea.com/products/5191/MRBF_Terminal_Fuse_Block_-_30_to_300A
msiminoff
Cheers
-Mark
'04 Alpenlite Saratoga 935, 328W of solar, 300Ah Odyssey batt's, Trimetric, Prosine 2.0
05 Ram3500, Cummins,Vision 19.5 w/M729F's, Dynatrac Hubs, RR airbags w/ping tanks, Superhitch, Roadmaster Swaybar, Rancho RS9000XL
The Overlhander Blog
DaHose
I have plastic coated tools I grab at when taking off battery terminals and on my coach battery I have a tool-less quick disconnect.
Jose
Harvard
CloudDriver wrote:
Learned that same lesson years ago with a car battery. Since then I always disconnect the ground cable from the battery before doing anything else.
x2
ledcomp
I use a non-metalic 3/8 ratchet extension. This way it does not matter if the ratchet bumps something. The only live part is the socket. Works great.
Matt_Colie
Wow, I bet you are the only one to do something like that.....
At least nothing took serious damage.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
hypoxia
I won't use a box wrench on a battery, an open end wrench can be knocked off of the nut easier.
Jim
2007 Monaco Signature Noble III ISX 600HP
DaHose
One of the screw lugs on my chassis batteries was blown clean off by a PO. Musta scared the poop out of somebody. Still works fine, but gives me a chuckle every time I open the hood.
Jose
westend
Yeah, plasma!!
I used to tape a wrench when I worked on batteries with similar terminals. Now, I just try to be conscious of where the metal is swinging.
You know, this might be just the start of a process. I worked my way up to cross connecting 460V welding stations. :B Unfortunately very little sparking but it is interesting to see that 300 lb machine dance on the floor.
'03 F-250 4x4 CC
CloudDriver
2003 Winnebago Minnie 24F - Ford E-450๐Ÿ™‚
