โAug-26-2019 02:30 PM
โAug-28-2019 12:23 PM
allen8106 wrote:
A 50 amp RV does NOT like 220. A 50 amp RV has two 120 volt legs and is not 220.
This 50-amp service has 4 wires with two 120-volt HOT feeds. It is a misconception that this 50-amp RV service is something special. This service is a STANDARD 120/240 50-amp 3 pole with 4 prongs used for numerous applications.
โAug-28-2019 10:41 AM
kmb1966 wrote:
how can a 30 amp rv plug fit into a 220 outlet? I have never seen one that fits.
โAug-28-2019 10:40 AM
Big Katuna wrote:
More info pls. Must have been a 30A RV. A 50 A rv likes 220.
How exactly did it happen.
โAug-28-2019 10:30 AM
MEXICOWANDERER wrote:
A three-wire 30 amp twist lock is light years more durable and secure.
โAug-28-2019 10:11 AM
โAug-28-2019 09:42 AM
xnizstudio wrote:
Everything seems okay! AC is still working and the refrigerator was cold this morning when I woke up.
It seems I got lucky ๐
โAug-28-2019 09:12 AM
โAug-28-2019 06:56 AM
Bobbo wrote:
Install it and forget it. I have. US made. User serviceable, if needed. Good warranty.
Progressive Industries EMS-HW30C
p220sigman wrote:
Thanks for the story. Don't let the negative people on here get you down. There are some on here that never met a dead horse they didn't want to keep beating.
Hopefully your other appliances are fine. I'm not sure how you could test them other than seeing if they work. You would need to know the test points and voltages to test the individual boards other than inspecting them for burned areas. You might want to fire up the fridge with a thermometer inside to make sure that it is cooling adequately and not just "running" though.
โAug-28-2019 06:47 AM
DrewE wrote:xnizstudio wrote:
Got the SINGLE pole breaker installed and the new converter and all appliances are working without damage .
Anyone who wants to argue about the dual pole breaker being wired incorrectly can read https://www.thespruce.com/installing-a-240-volt-circuit-breaker-1824649
A dual pole breaker provides 240v. A single pole provides 120v.
Iโm not an electrician and even I can google and find the above URL. The dual pole breaker was wired to supply 240v .
Bunch of ignorant people on here arguing about how it was wired incorrectly.. feel free to read the above URL
The claim is not that the breaker itself was wired incorrectly, but rather that the receptacle was wired incorrectly. A dual pole breaker is required for a 240V circuit (in North America), but that's not the only thing it can be used to power. It could also be applied to a pair of otherwise unrelated 120V circuits sharing a neutral, as in some areas is or at least was relatively common. It could be used to feed a subpanel which has 120V or 240V circuits. It could indeed also be used to feed a single 120V circuit, though it's rather silly to do so as a single pole breaker is smaller and less expensive.
At any rate, I'm glad you've gotten it all sorted out, and I'm genuinely sorry for the number of people who jumped on you for no good reason.
โAug-28-2019 04:57 AM
โAug-27-2019 07:40 PM
โAug-27-2019 07:39 PM
โAug-27-2019 06:29 PM
MEXICOWANDERER wrote:MEX, seems like you know about more than just batteries and charging systems.
All that plus 5 bucks will get you a cup of coffee at Starbucks. Be wise, and move on. A little bruised but a lot wiser.
A lying thieving neighbor just moved out after smashing my 100 dollar tail light lens and caught in the act thieving a motion detector lamp. He left the landlady a 700 peso electrical bill because she kicked his ass out and he had to move.
Sometimes life is a bowl of cherries complete with worms. But put it into perspective -- a car bash is a lot worse, right? or a slip and a broken leg. Or a stroke.
SHINE
IT
ON
โAug-27-2019 06:24 PM
SHINE
IT
ON
