โDec-26-2021 11:33 AM
โDec-27-2021 07:10 PM
pianotuna wrote:This is my experience also. But I will admit I almost never take my batteries to 50%. Why would I when I had a generator, and with the solar I don't even worry about it.
BFL13,
I just checked. The input wattage on the 60 amp PD is 1000 watts. That will not make a 2000VA generator run flat out.
โDec-27-2021 06:52 PM
time2roll wrote:The advantage of this is when OP hears his generator starting to slow down he knows he's charged.pianotuna wrote:Add 30% PF for 1300 apparent power and you are very close to the Honda 2000 rated output of 1600 VA.
BFL13,
โDec-27-2021 06:45 PM
pianotuna wrote:The PD bulk voltage is 14.4V whereas the Iota is 14.75V. This is why I don't like my DLS-35, it bulks too high for my 100Ah DC29.2112 wrote:
Considering battery longevity, does OP want to charge his two 6V 220Ah Costco batteries at 60A? That's over 20%c. Going that high occasionally wouldn't be a concern but should that be his SOP?
Need to weigh generator run time vs battery longevity?
At 13.6 volts that's not really going to matter much. What is recommended is .125 C. With 220 amp-hours that works out to 27.5 amps.
Above 85% state of charge, if the voltage is higher than needed, the battery will gas.
BFL13,
โDec-27-2021 06:24 PM
โDec-27-2021 06:14 PM
โDec-27-2021 06:00 PM
โDec-27-2021 05:46 PM
โDec-27-2021 05:27 PM
opnspaces wrote:BFL13 wrote:
How much hands on are you willing to do really?
(your 6s must be sulfated from never seeing any 14.x)
BTW when the trailer is on shore power, the Iota will be at 13.6 and if the other charger is on the batts too at 14.x, it will be doing all the work. No problem. When the 14.x is stopped, the 13.6 is still there carrying on running the rig 12v.
So what converter choices for doing the single stage 14.x:
1. PowerMax LK model in single stage mode (least expensive)
2. PD Li model 1st generation that only does 14.x (expensive)
3. PD standard three stage with CW--does 4 hours at 14.x but you have to make it do that (you said that is too much work) (also expensive) If four hours is not long enough time to get to 100 when back home, hit the CW again for another four hour run.
Thanks for the input BFL13 and Gdetrailer, you've both given me some things to think about. As it is I'm sure my existing batteries are severely sulfated and I plan to replace them as a just because in the next week or so.
As far as hands on, I was originally thinking about just replacing my existing 13.6 amp charger with a PD in the same location. But as many of you have mentioned I could just add a second deck mount in the front pass through.
BFL, When you mention CW I assume you are referring to using the PD pendant to put the charger into bulk mode. I was assuming that once I used the pendant to put the charger in bulk mode I would have to remember to turn it back off again or risk boiling my batteries. I see from reading the manual again the bulk will shut off automatically so the pendant is back on the table so to speak.
Gde Yes the batteries are on the tongue and I do have front pass through storage on the trailer so relocating there would be easy. And if I only have to add an outlet with 14 gauge romex that is extremely easy and cheap as I already have everything in my garage.
Hmmmmm here's my latest thinking now. I'm thinking about BFL's option #3 with a 60 amp deck mount PD in the front pass through. Yes I know I could make it a portable and put it out on the tongue but don't really want to do that. Since it's a 3 stage I'll probably disable the Iota and just run the PD pendant up into the cabinet next to the bed. Then I can just push the button as needed.
โDec-27-2021 04:46 PM
opnspaces wrote:
one last question for any of you who run an inverter generator. Currently my Honda 2000i basically idles when plugged in and charging. I assume this is because the charger is stuck at 13.6 volts.
If I go to a PD 45 or a PD 60 amp I'm assuming the generator is going to ramp up a bit and make some noise. Does your 60 amp charger cause the generator to really ramp up and put out some noise? Or does it still stay fairly low in the decibel range?
And back to dieseltruckdriver. Yes I agree solar is probably the best way to go, but I'm not there yet on it.
Thanks again everybody, I really appreciate the input.
โDec-27-2021 04:10 PM
โDec-27-2021 04:09 PM
The PD will equalize every 21 hours of non use of the battery.This doesn't matter to the Iota the way you want to use it. I don't know about the PD but in the Iota the boost and equalize are the same voltage, 14.75V. If the battery voltage drops below 12.8v the Iota goes into boost, regardless of elapsed time.
The Iota will equalize after every 7 days of non use of the batteries
โDec-27-2021 04:01 PM
โDec-27-2021 03:55 PM
โDec-27-2021 03:53 PM
