air chunk
joe0508
do they make an air chunk adapter for an air compressor that will screw onto the valve stem of an rv tire?If so what are they called?
joe money
7 REPLIES 7
westend
Second or third thread about the OP's problem while airing a tire. Have you tried replacing the wheel's stem valve?
'03 F-250 4x4 CC
j-d
No HarborFrightBashing on this one. One of my HF Favorites and on sale $2.99.
If you're trying to screw something onto a valve to extend your reach, just get one or more plain old extensions and put them on while you air up.
OldRadios
A clip on would be better. You will most likely loose some air when unscrewing a screw-on chuck. Lots of different style clip-ons available.
2006 Fleetwood 26Q
2010 Harley Softail Toad
2015 Ford Focus Toad
Upstate (the other) New York
K_Charles
Yes they make such a thing.
RJsfishin
An adapter for what to what ? Make yourself clear !
And are you talking a CHUCK or a CHUNK....of what ?
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
Bumpyroad
the only place I have seen screw ons is on the small hand pump/inflaters for bicycles, etc.
bumpy
gbopp
You can get a Clip On Air Chuck.
I don't know about a screw on type. Do a search for 'AIR CHUCK'.
