Air Conditioner not working. Help Please
Streff
Good morning,
One of our rooftop ACs stopped working a week ago. when it is turned on, all I hear is a constant humming noise. When I only turn the fan On (without cooling), same humming noise.
I took the shroud off and moved the fan wheel and it seems to move freely. Nothing looks a miss by appearance.
Any advice or guidance would be much appreciated.
Simon
2007 MADP
We shall pass this world but once.
Any kindness we can do, or goodness show, let us do it now
10 REPLIES 10
Streff
Thank you all for responding with great ideas,
The weather cleared up a week ago and I did test the AC by turning the fan by hand while having the AC in the ON position. The AC started but stopped sometime later.
I quickly ordered a Fan Condenser from Dometic that arrived a few days ago. I installed the new condenser and put everything back together. Now when I turn the AC "ON", it runs for a minute or so (with a very loud noise) and then it stops. All that remains is a deep humming noise. Let it sit for a few minutes, start the AC gain.. same thing... Starts and stops..
Any ideas how I can proceed with further testing or swapping out of parts.
Thank you for all your help
Simon
Chris_Bryant
Most have a single fan motor driving both blowers- though some do have separate motors.
-- Chris Bryant
opnspaces
Navigator II
Navigator II
Which fan should the OP be concentrating on? I thought the roof fan was for the condenser core only and there is a fan that blows air inside the RV located behind the ceiling grate?
Yes you still might have a bad run capacitor, but make sure you're looking at the correct fan.
PaulJ2
Hard start cap is for the compressor motor only. Fan motor has a run cap only. Yes, it is probably bad.
dusky203
This....
Chris_Bryant
A bad fan capacitor would be my first thought. You can easily check by spinning the fan blade and turning the power on- if the blower keeps running, the fan capacitor is bad- if you can spin it backwards and it keep running, the fan capacitor is definitely bad.
-- Chris Bryant
RoyB
Usually when my Air Conditioner hums it is due to LOW AC VOLTAGE from the camp ground pedestal connection.
I always have one of these RV AC VOLTMETERs plugged into a receptacle where i can glance at it when turning on my Air conditioner. This model is great as it has the SAFE ZONE printed in "GREEN"...
Gives me the warm fuzzy feeling...
I also have this setup with me for checking the camp ground pedestals before hooking up my 30AMP SHore power Cable but I have to admit I don't do this as much as I used to..
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
Streff
Thank you for the comments/suggestions.
The fan does not run at all. But it does turn by hand. So all it probably mean is that the motor is not stuck.
I will go back up in the roof and check carefully if the part mentioned above is damaged. Thank you for the tip. It's raining right now though.
What about a bad capacitor. I hear folks talking about that as a common culprit. Would that disable the fan from working?
Simon
dusky203
Does your fan turn at all? You might have a fried fan motor....Does your evap coil get cold?
Tim
ScottG
I suspect the hard start cap has failed.
Take the cover back off and look for a black thing with two connections on top thats about the size of a roll of half dollars.
It may even be physically damaged - look to see if the top is lifted and/or leaking stuff out of it.
This is a cheap part and you should be able to get one from any RV supplier.
Here's a fuzzy pic of a failed part:
