Anode Rod Wear
Mr__C
What would cause severe wear to the rod at the connection end? Almost no wear on the rest of the rod. I use teflon tape on the threads. Two brand new rods, two years in a row.
2020 Keystone Cougar 26RBS "Pressure Relief 4"
2017 Silverado LTZ 6.2 4x4
MM2 USN 1970-75
USS Canisteo AO-99
USS Miller DE-1091
"Knowledge is good". Emil Faber
22 REPLIES 22
Mr__C
It's this rod. I'll just plan on buying a new one before camping season.
https://www.amazon.com/gp/product/B075MNVPSX/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
MM2 USN 1970-75
USS Canisteo AO-99
USS Miller DE-1091
ktmrfs
MFL wrote:
fj12ryder wrote:
Ours always erodes quickest nearest the threads, which I believe is the reason: closest connection. But just a guess.
Mine too, and same guess.
yes, basic chemistry and electrolysis. I will corrode from the end closest to where it is attached to the tank and progress down towards the far end.
2011 Keystone Outback 295RE
MFL
Nomad II
Nomad II
fj12ryder
Howard and Peggy
"Don't Panic"
enblethen
There are two different materials used for anodes, magnesium and aluminum.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
NorseNW
My wear like that as well. I've always thought it's the area closest to the other metal source so it wears more there than the "free floating" end. Not sure I'm correct on that but it appears the anode is doing what it is suppose to do.
HARD water.. LOTS OF MINERALS in the water your using
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
enblethen
Are the rods the same manufacturer and which manufacturer?
Something in the water or wrong anode material for that water.
Bud
USAF Retired
Pace Arrow
