Another 'Am I dumb or is this broken?' question
Naio
I seem to have a lot of these.
I got an auto electric place to put in some stuff for me. Some of it involves Anderson connectors. I hooked one up today (inverter to house battery) and it was a little stiff plugging in but then I could not get the dang thing unplugged! Had to make a friend do it.
It's been a while, but they should just pull apart, right? There's no thingy to press on or anything?
Is it ok if I just file down the contacts a bit so I can unplug the dang thing on my own?
3/4 timing in a DIY van conversion. Backroads, mountains, boondocking, sometimes big cities for a change of pace.
14 REPLIES 14
Naio
Aw, Mex, you is a card :B
MEXICOWANDERER
DUMB? YOU? MY FOOT!
If we're talking can't walk and chew gum, here are some snickeroos...
Q: Why do blondes take the pill? A: So they know what day of the week it is.
A redhead tells her blonde stepsister, "I slept with a Brazilian...." The blonde replies, "Oh my God! You ****! How many is a brazilian?"
Q: Why did God give blondes 2 more brain cells than horses? A: So they don't **** in the parade.
Q: What's the mating call of the blonde? A: "I'm sooooo drunk!"
Q: What do you call 10 blondes standing ear to ear? A: A wind tunnel.
Q: Why did the blonde stare at frozen orange juice can for 2 hours? A: Because it said 'concentrate'.
Q: Why do blondes wear ponytails? A: To hide the valve stem!
Q: What goes: vroooom-schreech, vrooom-schreech, vroooom-schreech? A: A blonde at a flashing red light
Q: What do you call an eternity? A: Four Blondes in four cars at a four way stop.
Naio, I hope this put a smile on your face (and everyone else too) "Dumb" people do not ask questions.
Naio
I get that dielectric is better, but is it ok to go ahead and use lithium since I have it and am not near a store? These are for charging my shave ice nachine off the alternater - 85aH gel cells.
Mex, thanks very much for the suggestions for better connectors for future jobs.
Pa_La_O_La
NinerBikes wrote:
handles, and dielectric grease would do it.
Amen to Dielectric. Right tool for the job!
MEXICOWANDERER
For amperes up to 16, I MUCH prefer Weather Pack connectors to Anderson. Zero question. A much better designed and easier to use connector. Anderson for +16 amps, but then if space permits a dual-pole Pollak or Cole Hersee split pin is the hot setup. With crippled hands I have nothing but curse words for Anderson Power Pole Connectors. But this is a personal issue.
NinerBikes
pianotuna
Nomad III
Nomad III
Hi,
I'd use deoxit instead of grease. Handles are a great idea.
Regards, Don
Naio
@smkettner: I think I will order some of those handles.
Naio
Thanks, guys! Yes, I have lithium grease (and silicone spray).
Hmmm.. maybe I should pack those things. I used to carry a film container of lithium grease when bike touring.
I thought about asking my friend to plug and unplug them a few times, but I saw the look on her face when she saw me thinking it. She had to go through some pretty complex contortions to get them apart once.
westend
Naio wrote:
Orly? Lubricate with what?
Grease on the metal bits. Wax on the plastic. Silicone spray on everything in a pinch.
'03 F-250 4x4 CC
GMandJM
You're not dumb, Naio.
Some connectors are just VERY tight and hard to get apart -especially for those of us with limited dexterity.
They may loosen up if you plug and unplug them a few times.
G-half can always find a way to do things upside-down, inside-out or backward.
It's his Super Power!
time2roll
I would probably just apply some white lithium grease very sparingly with a cotton swap.
Here is a pull-handle kit if that would help: (near bottom of page)
http://www.powerwerx.com/powerpole-accessories/
Naio
westend
Lubricate the connectors, don't cut the metal contacts.
'03 F-250 4x4 CC
