Any good / easy way to find power loss on 12V house side?
michelb
The 12V batteries in our motor home discharge quite quickly so I'm thinking I probably have a short somewhere. Our 4 6V are new from May/2013 (Costco). With the disconnect turned to disconnect, I think they don't really lose much but if the batteries aren't disconnected, I think I'll easily lose .5V overnight with nothing on except for normal residual (LPG detector and others, water pump (but not used), etc). I don't think that's normal but maybe I'm wrong.
Any suggestions on how I can try to find where I'm losing Vs?
Thanks.
9 REPLIES 9
Wayne_Dohnal
If the temperature is lower for the 2nd measurement that will account for part of the voltage loss. You probably don't have a short circuit. What you're suspecting is often called a "phantom load". IMO the easiest way to start looking is to have everything you know about shut off, then one-by-one pull the 12 volt fuses and bridge the fuse holder contacts with an ammeter. A multimeter with a 10 amp range is good for this. This tells you which circuits are pulling power, after which narrowing it down further can get more complicated. Measuring battery SOC with a voltage measurement is approximate at best, and requires interpretation based on the the recent charging, load, and temperature situation.
2009 Fleetwood Icon 24A
Honda Fit dinghy with US Gear brake system
LinkPro battery monitor - EU2000i generator
MEXICOWANDERER
This thread is probably the best "User Ad" for the primary need of an amp hour meter 🙂
tenbear
The voltage drop down to 12.7v after charging is normal. This extra voltage is due to surface charge. The drop down to the high 11s seems high for a 4 GC2 battery bank. The battery bank has a capacity of about 450 AH and you apparently are using about 75% of the capacity. For best battery life you shouldn't discharge them lower than 50%.
Somehow, it seems that a lot of current is being drawn from the batteries. Without having current measurements all we can do is guess what the problem is. To use 300 AH in 12 hours means your average current drain is 25 amps.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
michelb
Thanks for the responses.
It will go down from 13V to 12.7 or 12.6 very quickly (maybe 30 minutes - enough that I thought the batteries were bad but it doesn't do it if the disconnect is 'disconnected') and I'll often go from low-mid 12s to high 11s overnight.
pugslyyy
Roadpilot wrote:
What is the start voltage and the end voltage? 13.2 down to 12.7 is one thing, 12.6 to 12.1 is another.
I agree. I have a sticker next to my house battery voltmeter to remind me -
12.8V or more = 100%
12.5V = 75%
12.2V = 50%
11.9V = 25%
Also gotta remember that is open circuit (no load) voltage. If anything is turned on it will pull the voltage down and you won't get a true reading.
To help me with troubleshooting, I have a clamp-on DC-ammeter. Makes it easy to check individual circuits. If you go this route make sure you get a DC model - some ammeters are AC-only which is useful around the home but not so much the vehicle.
tenbear
Good point Roadpilot. Could be just the surface charge leaking off, didn't think of that.
beemerphile1
Refrigerator? Maybe the heat strip around the door seal.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
tenbear
If it was me I would see how much current is being drawn from the batteries. With only the fridge and the various detectors on I would expect less than 1 amp drain. If more, I would start removing fuses and see where the current is going.
Without an ammeter you could remove all the fuses and see if the problem persists. If not, replace fuses one at a time and see when the problem returns.
Roadpilot
Tiffin Wayfarer 25TW
15 Mini Cooper S
