Our Atwood Stove top caught fire under the burner and melted the burner. It was red hot when we got it turned off. Soot on the underside of the cover suggests that the fire came from the air/propane mixing opening.
The back 2 burners still operate correctly and I'm guessing that the venturi was partially plugged causing the propane to exit through the mixing port.
The SS cover has that overheated metal look. Possibly it could be repaired but I'm giving serious thought to replacing the entire unit. Atwood has a new model (different valves/burners etc) that is otherwise a 100% drop in.
Thoughts? What's your experience with getting an Atwood replacement?
Atwood will ship the replacement. Left messages with 2 parts places and no response. One in San Jose and the other CW in San Margin, CA.
We have both BBQ and Coleman alternatives so we have some latitude for replacement.
2014 Grand Cherokee Overland
Bob
