Atwood water heater
marty1300
So my Atwood G6A-8E water heater won't light, hit the switch and no spark. If I hold a lighter by igniter it lights then shuts down. I notice the control board or spark module is leaking brown liquid and has a burnt area on the right side about 3/4 the way down. I did a google search for the module but no "exact" results came up. It is from/ in a 2011 Fleetwood Tioga Montara. Does anyone know if they make the part? I have an email into Atwood but have time to kill right now
Thanks for any input
Marty
Marty
8 REPLIES 8
marty1300
No flame or flair up , had cleaned burner tube and exhaust. It was an internal part of board diode, resistor Etc
Marty
Dutch_12078
Dinasour makes great products. I keep one of their universal ignitor boards in my spares that will work in either of our two furnaces and our water heater. I haven't needed to use it yet for this motorhome, but a spare board sure came in handy in our previous motorhome, when the OEM furnace board quit in 35 deg.F weather.
Dutch
2001 GBM Landau 34' Class A
dougrainer
Modules only "burn/melt" if you have had a flame Flashback. Caused by a burner tube restriction. You need to check and clean both the burner tube and the exhaust burner tube that goes thru the water heater. Doug
marty1300
I got the dinasour board and installed Thursday and have hot water once again- thank you for the advice
Marty
Marty
marty1300
Thank you guys I will check these out
Marty
Old-Biscuit
Atwood OEM circuit board 93865
https://www.amazon.com/Atwood-93865-Potted-Circuit-Board/dp/B0007XU4EC
Dinosaur Electronics Circuit Board.......better quality/pricing then OEM
(need protective cover for use in WH outside compartment)
Dino UIB S
Amazon Dino UIB S & Cover
enblethen
Go to Dinosaur Electronics
Compare your board to those shown.
They make a much better circuit board then Atwood potted ones. Less dollars!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
newman_fulltime
Go on eBay type in at two of water heater board
