Atwood Water Heater
JoLinontheroad
Had hot water in the morning, by dinner time no hot water. The tank is full of hot water and the LP runs to heat the water, but no hot water at the faucet, only barely warm.
RV is a 2017 Fleetwood Bounder 33C
4 REPLIES 4
2112
$12 on 6 & 8. Oh wait, wrong bet.
I'll take Shower Valves left on for 200 Alex
2011 Ford F-150 EcoBoost SuperCab Max Tow, 2084# Payload, 11,300# Tow,
Timbrens
2013 KZ Durango 2857
Dutch_12078
Also check that the shower and outside shower (if equipped) are turned off at the valves and not just at the shower head.
Dutch
2001 GBM Landau 34' Class A
dougrainer
Post MODEL of Heater. If it has EXT in the model you have a classic failure of the Mixing valve that is part of the Heater. Doug
BFL13
Sounds like the classic by-pass forgot to put them back to normal after winter ?
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
