โAug-29-2013 12:22 AM
โSep-02-2013 06:04 AM
โAug-31-2013 11:45 PM
Cstoliker wrote:westend wrote:
Yes, you need the pad ears to slide in their holders and, yes, good brake fluid in the system. What some may not realize is that this era of larger Ford chassis had significant problems with calipers sticking, It happens especially when rotors and/or pads are worn to the end of their lifecycle. There is something about the geometry of the caliper cylinder and the mating seal surface that causes them to stick in the extended position. I've repaired/serviced more than a dozen Ford trucks with the same problem. The ultimate fix was to replace the caliper and they should be done, at the least, in pairs.
So the old warn pads may have been the cause. I'll still do my line pressure test to confirm but that makes sense. Did the bad calipers you've seen from this stick randomly while other times work normally?
โAug-31-2013 11:09 PM
โAug-31-2013 10:56 PM
Gdetrailer wrote:John&Joey wrote:Cstoliker wrote:
As stated above its already been done. I cleaned and greased all the moving parts. Caliper does not have bolts. Just slide pins.
I've fought the same problem with my '96 Class A F53. Did all the standard stuff like you did. Replaced calipers with the best, and changed brake fluid every two years. Only way I could ever win. Even then, there were times I thought they were dragging after sitting for awhile.
Good luck, BTW backing up and hitting the brakes seem to help break them free.
Folks, in spite of what you think, it is not the calipers OR the pins.
The problem is the PADS FIT TOO TIGHT in the calipers.
What I have run into is the pads when new don't slide easily, once they sit they get the chance to RUST. Once rusted the pads no longer move back as they should after you let up on the brake pedal.
The fix, well believe it or not FILE the ears of the brake pads that fit in the caliper slots. If rusted you NEED to ensure ALL the rust is filed off.
In a nutshell, the brake pads MUST slide EASILY in the caliper holder, if they don't then FILE some of the material on the ears of the pads until the pads slide easily BY HAND.
I have had this happen to several trucks and had to use a hammer and chisel to get the pads OUT of the caliper.
I have thought about putting some anti seize on the ears but I am concerned about that getting on rotors, pads or collecting dust/dirt.
So far my "fix" has been working for several years on one of my trucks ๐
โAug-31-2013 06:18 PM
Cstoliker wrote:
Funny you should mention that. For me I was thinking backing up and hitting them are what caused it. The ride to somewhere was fine. It's after I get to the destination and backing up to park it was triggered it. And would drag on the way home.
โAug-30-2013 01:38 PM
โAug-30-2013 01:29 PM
MEXICOWANDERER wrote:
I changed to silicone brake fluid years ago and all this kind of nonsense went the way of the dinosaur.
โAug-30-2013 12:54 PM
โAug-30-2013 12:41 PM
โAug-30-2013 12:05 PM
โAug-30-2013 11:46 AM
โAug-29-2013 01:56 PM
โAug-29-2013 12:51 PM
โAug-29-2013 10:00 AM
