Apr-23-2014 05:40 AM
Apr-23-2014 07:10 PM
Apr-23-2014 06:04 PM
Apr-23-2014 06:02 PM
Almot wrote:
When voltage is rising, the current is dropping as the SOC is nearing Bulk setpoint (90%?).
Apr-23-2014 05:51 PM
Apr-23-2014 05:47 PM
Padlin wrote:
Then the amperage/current from the panels via the controller slowly raise the battery amperage and as they do the voltage at the battery, which is the same as that felt at the controller output slowly rises?
Apr-23-2014 05:06 PM
Apr-23-2014 04:43 PM
Padlin wrote:pianotuna wrote:
Hi,
PWM controllers operate at the battery voltage.
Pianotuna, I don't understand the 2nd part of this response, please elaborate. Looked like you set the controller for the type of battery which then uses the applicable settings. On some you can choose custom setting and set them to whatever you want up to the units max.
I am planning on just one panel to start and will see how it works out, we're not heavy consumers so hopefully one is enough. One panel that fits (narrow), would be either 100 or 130w's. Still have to measure for length.
Apr-23-2014 04:36 PM
Apr-23-2014 02:57 PM
MEXICOWANDERER wrote:I don't do this once a week but the occasional bubbling has all but eliminated my batteries requirement for equalizing. It's been about a year and a half since the last equalize. I'll probably need to do sometime in the next couple of months after I water them though.
I recommend a FRANCIS FREAS. BUT BUT BUT, by doing the timer battery bubbling twice a week or at least once a week you will reduce the need for using a hydrometer by 80% and the need for equalizing 90%.
Apr-23-2014 02:56 PM
Apr-23-2014 09:59 AM
Apr-23-2014 09:50 AM
pianotuna wrote:
Hi,
12 volt panels are nominally 17 volts. PWM controllers operate at the battery voltage.
Apr-23-2014 08:49 AM
