Battery Disconnect
KLYoung
A little confused here. I am installing a battery disconnect on my BattleBorn batteries and need to know whether to install it on the negative or positive cable. I seen discussion both ways.
9 REPLIES 9
2oldman
OP is gone.
Sjm9911
I did the negative as the switch i bough recomended it. Just make sure you dont forget to turn it on for the break away switch when towing. I wired mine so that was always powered.
2012 kz spree 220 ks
2020 Silverado 2500
Equalizer ( because i have it)
Formerly a pup owner.
CA_Traveler
The discussion was about disconnecting the battery.
Disconnect both the positive and negative battery cables and remove the batteries and you can still have the lights on from the battery charger.
2014 Grand Cherokee Overland
Bob
BFL13
I had a disconnect on the battery neg to frame wire and thought that would be ok. Nope!
Turned out that because the frame is the neg path for both 120v and 12v, that I still had a neg path aside from the battery to frame wire, when the shore power was plugged into the inverter and something weird was happening the way the inverter was wired so the "ground" wire in the 120v wire got to the "chassis" of the inverter which got to the RV frame.
Anyway, it was complicated. Can't remember all the gory details of which path went where or why I had it like that.
Bottom line is when the battery disconnect on the neg wire was "open" and the shore power cable was in the inverter, I still had 12v lights and fans working in the RV
So as others a trying to warn about, you can have another neg path somewhere, but if you have the disconnect on the battery pos wire close to the battery, you won't have another pos path somewhere.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
CA_Traveler
Electrically it doesn't matter as a switch disconnects the circuit, period. All postive or all negative wires must be switched.
The general battery safety rule it to disconnect the negative battery cable first on the battery and connect it last.
But this doesn't apply once the switch is installed.
Bob
ksg5000
May depend on how your rig is wired. Look for extra wires attached to your battery which you might have to relocate to accommodate add-on battery disconnect.
Kevin
2oldman
I seen discussion that it doesn't matter.
Lynnmor
That's because it doesn't really matter.
enblethen
I would install in the positive lead. Closer to the battery the better.
If something were to happen in the circuit if were installed in negative, you could have very serious issues. A ground any where in the system.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
