Generally youโll need one solar watt for each battery amp hour to recharge your batteries. In some parts of NoCal 1.5 watts per amp hour may be necessary. Solar is wonderful but only with adequate batteries, panels and controller, so surfing in to Costco or wherever and buying one panel and a questionable controller wonโt cut it.
Since you havenโt told us your daily total energy use (via an energy survey) there is no way to determine what you need in solar equipment...panels, controller and batteries.
Portable panels have their place but I will bet you my roof mounted panels were producing power before you put your panel out. And mine werenโt subject to theft or needed to be put away when you went out to dinner or at sundown. Sure you can point yours at the sun. Iโll just buy an extra panel. 100 watt panel is only a 100 bucks.
