Battery watering system
nvreloader
Guys
Any suggestions, thoughts or Idea's, on which battery watering system to get for 4-220A GC batteries?
These batteries will be tucked up inside the TH frame rails,
just ahead of the dual axles, of the new solar install.
Tia,
Don
2010 F-350,6.4PSD, 6spd man trans,CC,SWB,SRW, Caravan camper shell,50 gal bed tank,17,000lb Husky WD hitch,Northwoods 2008 28KS Desert Fox Toy Hauler,2005 Honda 500 Rubicon ATV w/rumble seat,1 Aussie waiting,watching and ridin shotgun on the whole outfit.
10 REPLIES 10
markchengr
I had a flowrite system (profill). One of the small red barb connectors broke allowing battery acid to spill into the battery compartment and I didn't see it until it started to run down the side of the RV. What a mess. I now have AGM's (2 six volts) and I was able to lay them on their sides for much easier hookup (all connections facing out), the only way to go in my opinion. Money well spent. -Mark.
NEOK
I use the Flowrite system I our boat and our truck camper. As mentioned it is not automatic but it helps put water in the batteries if they are hard to reach. I do think I will change over to AGM batteries I the future though.
neok
2009 GMC 25000HD Short Bed 6.0 Gas Engine Crew Cab SLT 4x4
2008 Bigfoot 15C9.5FS
Torklift Talons, Fastguns, Stableload Quick Disconnects, Superhitch & SuperTruss
Big_Katuna
They sound hard to get to. If so, I agree with Chris.
Also the Profil (which I have- it works fine) is not automatic so you still have to remember to get the hose out, connect the bulb and stick it in a jug and pump monthly.
AGMs dont really cost twice as much as they last twice as long.
My Kharma ran over my Dogma.
doxiemom11
X3 - That's what we have too. Worth every extra penny
2oldman
Chris Bryant wrote:
Honestly, forget the watering system and go with AGM batteries.
x2. Spend a bit more, get a lot more.
Chris_Bryant
-- Chris Bryant
Janss
I used the Flowrite Pro-Fill on a previous motorhome. Worked great!
2002 Itasca Suncruiser 32V
2012 Suzuki Grand Vitara
westend
This Flowrite Pro-fil RV system seems to be designed well. I haven't used one so can only recommend from observation.
'03 F-250 4x4 CC
azrving
We used flow rite on industrial batteries for years and did well.
