โDec-06-2013 11:56 AM
โDec-14-2013 08:11 AM
โDec-14-2013 08:08 AM
BFL13 wrote:
I think Fisherguy runs his PD9280 (non-PF corrected) with his. Probably can run the PF corrected PowerMax 100amper or WFCO 68100.
For near max load with a cold gen I recommend leaving Eco off at first, then turn Eco on a few minutes later.
โDec-07-2013 08:49 AM
โDec-07-2013 06:46 AM
ktmrfs wrote:pianotuna wrote:
Hi ktmrfs,
When I wrote PD they told me all their units are a power factor of 0.7. So the 1300 watts becomes about 1857 va. Not pretty with a genny rated for 1600 va. Then take it up above sea level. If the battery bank is truly flat with six six volts it is not going to be reliable.
The only reason it would work is if the pd doesn't zip up to full output i.e. with sagging voltage. I have seen that in person with the 40 amp pd in the RV I call home probably because the maker skimped on the wire size from the converter to the battery bank.
The person might consider solar?ktmrfs wrote:
True, the PD80 may draw about 1300 watts, but closer to 1600-1700 VA, so it's marginal on a honda 2000, right at it's continous rating. Like so many RV appliances, actual current draw is more than the "watts" rating indicates.
The PD60A draws on the order of 1400VA IIRC my measurements on one supplying 55A.
Thanks for the info and Wow, Looks like the PD80 is worse than I thought for draw!. I see why it requires a 20A circuit.
Sure am glad now that I went for the PD60A instead of the PD80. It's fine with the honda 2000 and my bank of 4 GC even at altitude. But it does give the honda a workout.
If I really need to "poor the coals" to the batteries, I dig out my second honda, parallel them and fire up the PD60 in the pass through and the PD55A in the panel and hit the batteries with about 110A. That combo will hold high current for quite a while before it starts to sag.
โDec-06-2013 08:11 PM
pianotuna wrote:
Hi ktmrfs,
โDec-06-2013 08:01 PM
โDec-06-2013 07:42 PM
โDec-06-2013 06:45 PM
โDec-06-2013 06:12 PM
โDec-06-2013 05:53 PM
wa8yxm wrote:
3 pair of GC-2 batteries can suck about 180-200 amps of power if you can find a converter that big.. I do not think you will.
A 1,000 watt GENRAC portable generator (True 1,kw) can power a PDI 9180 with a single pair of dead GC-2's. I know. I killed them and restored them to charge.
I would say 150 amps is possible with a Honda 2000, (Not a true 2kw generator)
But I do not think you will find a converter that big.
โDec-06-2013 05:47 PM
ktmrfs wrote:RoyB wrote:
The front panel of the Honda EU20001 says 13.3AMPs at 120VAC... That is around 1600WATTS...
I use my 2KW Honda to re-charge my three 85AH batteries in parallel using a PD9260C COnverter. I read 52-53AMPS DC Current being drawn by my battery bank for about 10 minutes then it start dropping back.
I can recharge my three batteries back up to the 90% charge state with-in a three hour run time on my 2KW Generator.
I think the PD9280 Converter input watts is around 1300WATTS at 120VAC so the 2KW Honda Generator should run that ok. IT does however state you should plug the PD9280 converter into a 20AMP receptacle, I think the 2KW Honda Generator only has a 15AMP 120VAC receptacle on it....
I suspect you do not have enough WATTAGE capability from the 2KW Honda Generator to re-charge your battery banks back up to 90% charge state in a three hour generator run time period. The rule of thumb is somewhere around 20AMPs of DC current for each battery in your bank to obtain a 90% charge state in a short three hour generator run time.
Maybe the experts will dime in here on what you need to make it work...
Roy Ken
Roy,
I get on my soapbox about generators, appliances, watts and volt amps to often, but here it goes again, since it often results in folks either getting something that doesn't work, or trying to figure out what is going on.
I do agree, the honda 2000 and a PD60A converter make a reliable great running combo. That is what I use and the generator has enough reserve to run the PD60A and 100-200VA to spare if needed.
the issue is that the honda is NOT a 1600watt generator unless connected to a resistive load. It is spec'd as a 1600VA (volt amps) generator.
Chargers like the powermax are "power factor corrected" So the watts and VoltAmps are very close to the same. Kudos to them for addressing an RV issue.
Unforetunetly, IMHO generator mfg and RV parts mfg are doing folks a disservice by stating only watts. They should have a watts and VA spec. That way folks would have a better idea of what will work.
There are generators that have seperate specs for watts and VA.
โDec-06-2013 05:45 PM
Roy Ken
โDec-06-2013 05:32 PM
โDec-06-2013 05:09 PM
landyacht318 wrote:Yep, but it's going to work the little guy pretty hard.
I've recommended the powermax 100 amp as its 1440 watts figure is still below 1600 watt maximum of the honda 2000.
