โAug-27-2016 08:31 PM
โSep-11-2016 05:17 PM
โAug-29-2016 05:25 PM
Bobbo wrote:Gdetrailer wrote:Bobbo wrote:
A solid check engine light means check the codes whenever it is convenient.
A blinking check engine light means pull over, stop and call a tow truck.
No, not even close.2008 Chrysler Town & Country Manual wrote:
19. Malfunction Indicator Light
This light is part of an onboard diagnostic system
called OBD that monitors engine and automatic
transmission control systems. The light will illuminate
when the key is in the ON position before engine
start. If the bulb does not come on when turning the key
from OFF to ON, have the condition checked promptly.
Certain conditions such as a loose or missing gas cap,
poor fuel quality, etc. may illuminate the light after
engine start. The vehicle should be serviced if the light
stays on through several of your typical driving cycles. In
most situations the vehicle will drive normally and will
not require towing.
If the Malfunction Indicator Light flashes when the
engine is running, serious conditions may exist that
could lead to immediate loss of power or severe catalytic
converter damage. The vehicle should be serviced as
soon as possible if this occurs.
emphasis added
โAug-29-2016 04:25 PM
โAug-29-2016 02:34 PM
โAug-29-2016 12:59 PM
โAug-29-2016 11:16 AM
No, not even close.
not require towing.
โAug-29-2016 08:43 AM
Kayteg1 wrote:
When CEL on most vehicle is mostly emission stuff, it is the unknown that can kill our mind.
Would you drive your coach without fuel gauge?
So why you hesitate to spend $20 for Bluetooth reader, or $30 for independent scanner?
โAug-29-2016 06:03 AM
โAug-28-2016 08:27 PM
โAug-28-2016 08:15 PM
stew47 wrote:
So the light started blinking and stayed on under hard acceleration. It's a 2008 f350 with 6.8. Truck didn't seem to be lagging in performance. Tomorrow I'll go to autozone and see what code it threw but first anyone have any experiences of what they did?
โAug-28-2016 06:28 PM
stew47 wrote:
Well I notice eBay has complete tune up kit with cops, plugs, fuel filter, air filter, pcv valve for 300$. Maybe it's just easier to do at home i dont know. Is there a good place to get the plug socket that's magnetic and long enough extension?
โAug-28-2016 05:21 PM
โAug-28-2016 03:32 PM
stew47 wrote:
Lol helps greatly. Sensory overload! Makes me think I might drop off to mechanic so I don't start the costly process of changing parts. I bought with 169000 and I have 174000 on the odometer now. No idea when plugs were replaced or if any cops have been changed out. Since its at full throttle what do you think about fuel filter as a first step? I guess I could pull a plug out and look at the general condition. I've watched the videos about using carb cleaner to dissolve carbon on plugs first but still scares me
Thinking further about when lights went off the truck didn't seem to have quite the power as normal which I guess could be starving for fuel or a cylinder dropping out.
โAug-28-2016 03:01 PM
Happened to my brother once as he was pulling off the freeway in his Detroit Diesel Powered Semi. His made it to the end of the ramp and coasted onto the shoulder.. Buddy said "Wooee, Looks like the clown car at the circus with flames shooting out from under the hood"
He left the terminal with a Detroit Diesel under the hood. By the time he stopped (near instant after the light came on) He had two halves of a Detroit Diesel under the hood.. Not so little brother (6'6.5" tall to my 6'3" but younger) is a certified Diesel Mechanic (Also Auto) Inspected it, Hitched a ride to the truck stop a short distance away..Called Detroit D His buddy dropped his trailer and they went back intending to pull his tractor out from under his trailer, then pick up his trailer and tow it to the truck stop.. Tow truck was already hooking up to tractor (Detroit D sent the Tow) so they took the trailer back.. Detroit had a new engine, AND an installer, on a plane the next day putting it in and he was on the road again.
Blinking Check Engine is serious.
โAug-28-2016 02:24 PM
