Brake Lights
fantasy_islande
Doing a check as we prepare to leave for home, and the brake lights are not working. No voltage on the power lead, 20A fuse is good. FTL raised rail chassis.
Joe & Cathy Sikora
2010 45' Mandalay Quad Slide, Freightliner XL Tag, 425 Cummins
2018 Chevy Traverse Premier
Stan & Ollie
Afghan Hound Rescues
8 REPLIES 8
MEXICOWANDERER
Separate tear lamps
One for turn
A second for brake lights?
Yes it's important to know
midnightsadie
did you pull an clean the fuse? some times they crud up. been there.
fantasy_islande
Thanks to all for prompt replies.
I also found no power to the hitch brake pin.
Both fuses are good and have 12V.
I now remember that the brake did not disconnect cruise when we came down.
I agree that suggests a defective switch, but I've looked at the pedal area, and the only connection I see coming out of it is the pedal motor.
I looked at the firewall, but there are a thousand wires, and I have no idea what the switch should look like if it's there.
I'll call FTL for direction.
Thanks again.
Joe & Cathy Sikora
Stan & Ollie
opnspaces
Navigator II
Navigator II
Do the emergency flashers work?
Lwiddis
Ground first IMO.
Cobra21
Optimistic Paranoid wrote:
If you're SURE the fuse is good, I'd be checking the brake light switch next.
Brake light switch at pedal and the ground.
Brian
Optimistic_Para
ScottG
Is there power at that 20A fuse when you check with a meter?
