โNov-15-2015 05:41 PM
โNov-16-2015 04:17 PM
โNov-16-2015 02:19 PM
โNov-16-2015 12:15 PM
westend wrote:
Yeah, you should get some more current through the switch to make the lights work. I'd suggest to install another battery on your truck.
Amateur Radio K3EXU
โNov-16-2015 11:58 AM
โNov-16-2015 09:10 AM
โNov-16-2015 08:57 AM
bearwayne wrote:
Shouldn't the tail lights come on when the breakaway switch is tested?
โNov-16-2015 07:39 AM
Bobbo wrote:
You will have to take our word for it. The brake lights and the brakes are 2 completely separate circuits. Your tow vehicle activates both when braking. Think about this, the brake lights are on or off. They are all or nothing. They don't get brighter the harder you press the brakes. The brakes are proportional. The harder you press the vehicle brakes, the more power is sent to the trailer brakes, the harder the trailer brakes are pressed. The breakaway switch only activates the brake circuit. It is not hooked to the brake light circuit so they don't illuminate.
If the cars following you when you have your trailer break away can't tell there is a problem, the brake lights probably won't help.
โNov-16-2015 06:05 AM
โNov-16-2015 03:41 AM
โNov-16-2015 03:35 AM
โNov-15-2015 06:35 PM
โNov-15-2015 06:20 PM
โNov-15-2015 05:58 PM
bearwayne wrote:
Yesterday, I replaced the cable that connects the 5th wheel to the 7 pin connector on the truck. Luckily, the cable I ordered used the same color scheme as the existing cable (I tested old and new cable with a multimeter) and after connecting everything, the tail lights, turn signals, brake lights and running lights all worked as they should.
Then I decided to test the breakaway switch. I could not tell that anything happened when I pulled the pin. I checked the wire from the breakaway switch and I had voltage. Today, I tested it again after filing the contacts in the breakaway switch with a nail file. Again I had voltage (I think it was 12.5V), but the brake lights don't come on and I don't hear the brakes humming. I reattached the cable to the tow vehicle, and I can hear the brakes humming when the brake pedal is pressed as well as when the manual switch is pressed on the brake controller.
Shouldn't the tail lights come on when the breakaway switch is tested? I suspect that not enough current is passing through the breakaway switch to activate the brakes and the brake lights (I don't have an ammeter to test it.) I have already ordered a new one from Amazon.
โNov-15-2015 05:56 PM
