BTU per pound Propane vs ULSD
MEXICOWANDERER
Having a devil of a time with web connection. For friends in the mountains. RV patio heater.
Thank You
My interest is I visit them ๐Ÿ™‚
22 REPLIES 22
kellertx5er
MEXICOWANDERER wrote:
Since LPG has a weight per cubic foot density similar to diesel it would make sense that BTU specs would be the same. However substituting LPG as a motor fuel reveals a drastic sum difference in economy. This is curious.
Water has 20% greater density than diesel, but I have yet to find a way to burn it!
Keller TX
'19 Chevy 2500HD 6.0L
'09 Outback Sydney 321FRL 5er
SUPPORT TEXAS STATE PARKS
MrWizard
Moderator
Moderator
i was thinking something similar
engine operation, depends on flame propagation and the pressure created in the combustion chamber, to drive the piston down
I can explain it to you.
1997 F53 Bounder 36s
JaxDad
Simple science actually, propane makes the same(ish) heat as diesel but it doesn't explode as fast as vapourized diesel, especially under pressure, so it takes a lot more propane to accomplish the same work.
Thus when burning it slowly (compared to an ICE) you get similar heat, because the losses are mostly eliminated.
MEXICOWANDERER
DrewE
Since they're both hydrocarbons, I guess it rather makes sense that per pound they have similar energy content.
Per gallon, USLD has about 50% greater energy density (and ordinary mass density).
MEXICOWANDERER
I need to do more research ๐Ÿ™‚
Kerosun 10,000 BTU heater says one gallon lasts 10-12 hours. A 10,000 BTU LPG heater would therefore last 8 hours or so with a gallon of LPG?
A gallon of ULSD costs $3.90 down here. LPG is about $2.50 gallon but a lot more inconvenient.
Maybe a larger tank? Sure goes not seem to be a lot of difference in energy per gallon or per lb.
pianotuna
Nomad II
Nomad II
138370 Btu per gallon for ulsd
about 7 pounds per gallon
so 19767 btu's per pound.
Regards, Don
MrWizard
Moderator
Moderator
One gallon of propane has 91,502 BTUs
1 gallon of propane weighs 4.2 pounds. A "full" 20 lb cylinder should have 4.7 gallons or propane in it.
91502/4.2=21786.19 BTUs per pound
