โJan-11-2023 04:16 AM
โJan-28-2023 04:11 AM
โJan-14-2023 07:33 AM
MrRetired821 wrote:
my better half says get a new cooling unit.
โJan-14-2023 07:28 AM
MrRetired821 wrote:dougrainer wrote:
Blockages are as hard as a weld and are attached in the upper coil area and CANNOT be broken loose. So, burping just rearranges the Ammonia temporarily to work a little longer. It works but NOT AS WELL AS BEFORE THE BLOCKAGE. IT WILL FAIL AGAIN. Rebuilders cut out the tubing where the blockage is on blocked units and then weld a new upper tube assbly in place, then charges the cooling unit. THERE IS NO WAY THAT MOBILE TECH FOUND A BLOCKAGE, UNLESS HE STUCK AROUND FOR 2 OR 3 DAYS AND DID VARIOUS TESTS. TEMPORARILY UNBLOCKING A UNIT REQUIRES THE REFER TO BE TURNED UPSIDE DOWN FOR 24 HOURS AND THEN RIGHT SIDE UP FOR 24 HOURS. Then start a cooling process. You could have just had a glitch and if the refer continues to cool (below 38 degrees in the refer and below 10 degrees in the freezer), I would not worry about it. Also, it could have been as simple as the rear cooling fans did not run. Did the Mobile tech checked those? Doug
PS, is the refer in a slide room?
The tech used a heat measuring gun and found the top tube hot on the left side and it cooled off right in the middle and continued cool the rest of the loop. Seems logical to me that where the heat stopped and the cool begin theres the problem.
The fridge is in a slideout. One of the fans was stopped up with mud dobbers nesting on it. Once flipped, it gurgled a few minutes and then we flipped it right side up. powered up and working still. Steady 34 degrees in fridge.
Note: we were camped in Davis Mountain State Park and temps got down to single digits a couple of days before it quit working.
thanks
Mod Edit: fixed the quote
โJan-12-2023 09:00 PM
โJan-12-2023 02:41 PM
โJan-12-2023 12:28 PM
โJan-12-2023 11:40 AM
โJan-12-2023 08:15 AM
MEXICOWANDERER wrote:
Sal at Kool Fun and I spent a lot of time tracing down blockage issues with Dometic and Norcold. Since he built absorbsion cooling units and was a warranty station for OEM he was no backyard boltstripper.
We filtered out manufacturers welding SLAG from cooling unit media. Could be slop right out of manufacturing UF ring or broken loose later.
Before hassling with removal try shutting the unit down for several days. If it then operates normally Slag is percolating slowly but surely up through solution and will re block the same orifice.
Aftermarket replacement cooling units did not exist at that time so I have zero information about their success rate.
The blockage was where the dimples are at the top. Afer the burping its working fine. I did turn it off and let it sit for 24 hrs, turned it back on and it again working normal. Oh the unit is out of its cabinet and sitting on living room floor.
The unit if probadly 10-11 years old and this is first problem.
appreciate your response.
I do know with giant lithium bromide chillers used for mass cooling the manufacturers spend an enormous amount of time and resources flushing and reverse flushing their production line products. Violent velocity scrubbing to remove manufacturing welding slag.
Again remove the heat from your RV refrigerator and let it sit in place for several days then try it.
The practice of "burping" absorbsion refrigerators began 90 years ago with Servel brand stand alone units. They were made in Sweden with much thicker high alloy Swedish steel.
Hope this helps
โJan-12-2023 07:22 AM
โJan-12-2023 04:34 AM
Chum lee wrote:MrRetired821 wrote:
Thanks for the responses. I guess I'm trying to convince myself to gamble with the burp thing. However, my better half says get a new cooling unit. BTW the fridge is still working like it should, but it's parked at the house.
You haven't stated HOW MUCH you DEPEND on your RV for the necessities of life. IMO, if it's a vehicle that you occasionally use to venture into the wild blue yonder and you have many options available to you, I wouldn't hesitate to take a chance on it. (It's not that hard to fix if/when it breaks, it's just $$$) But if you (and others) deeply boondock regularly and ALL your favorite perishable foods are stored there, . . . . well, I would replace it tomorrow. (at least the cooling unit if there's no other physical damage)
Chum lee
โJan-11-2023 06:47 PM
โJan-11-2023 03:33 PM
โJan-11-2023 01:10 PM
โJan-11-2023 07:04 AM
