Can I use Pro-Flex under screw heads?
solismaris
Hi rv-ers,
On side corner seams I am using Pro-Flex caulking on the edges of the metal trim pieces where it meets the walls. What about the screws? Several are loose and show signs of slight water intrusion. Can I back out the screws, add a dollop of Pro-Flex to the hole, and reinsert the screws? I also plan to use Pro-Flex over the screw heads too.
I don't know if Pro-Flex is the ideal caulk for the purpose but would prefer to use it if it is workable rather than track down yet another specialty product.
David Kojen
9 REPLIES 9
solismaris
CaLBaR wrote:
I pulled out each screw on the top gutters put a blob of proflex on and screwed the back in. No more leaks from there now.
That's what I ended up doing too. After the screw was tightened down I then covered the head with pro-flex too, which I smoothed nicely with a paint-thinner moistened finger.
We'll see how it lasts. I think it should be quite durable.
David Kojen
CaLBaR
2018 Grand Design Reflection 297RSTS
2019 RAM 3500 SRW Big Horn 4x4, 6.7 Cummins/Aisin
2007 Rockwood 8298 SS (Traded in 2018)
2009 Toyota Tundra 4x4 Crew Max 5.7L (Traded in 2019)
HP Dual Cam Sway Control
Prodigy Brake Controller
westend
I used small pieces of Eternabond Webseal. It resulted in exactly the same sealing like this video.
'03 F-250 4x4 CC
solismaris
Pirate wrote:
Jacksons wrote:
I replaced all the exterior screws with stainless steel screws,1 size larger, and put rope caulking in the hole before inserting the new screw.
Stainless screws are actually softer than others, such as zinc. I like stainless but don't like when the heads strip out.
True. More than strong enough for the job I think though
David Kojen
Pirate1
Jacksons
2002 Rockwood 8272s
2005 Yukon xl Denali 6.0
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.
Thomas Jefferson
solismaris
DougE wrote:
I just put a little silicon caulk on the threads. This helps secure the screw and prevents rusting of the sheet material.
I won't be using any silicone anywhere near my trailer. It messes up adhesion of the other products I use, like Dicor and Pro-Flex. Too risky as I'm sure I wouldn't be able to keep it just under the screws.
David Kojen
DougE
Currently Between RVs
donn0128
Sure tou can. I only tried that once and it was terrible to work with. Much prefer Dicor.
