โNov-19-2017 02:56 PM
โNov-20-2017 02:23 PM
enblethen wrote:
You need to identify the wire the blue leaves from the circuit board at the switch end.
The switch should have a wire that comes from the 12 volt DC positive, a wire that goes to the circuit board, brown input, the return, blue wire from the circuit board and a negative from the 12 volt system.
Added up that is four wires.
Look at page 7 of the manual, upper right corner.
Where did you get switch? It is the wrong one!
โNov-20-2017 01:28 PM
Bud
USAF Retired
Pace Arrow
โNov-20-2017 12:43 PM
enblethen wrote:
The blue wire from the circuit board should go to the switch light then to 12 volt negative.
What is shown in last photo is the light would come on when switch is on "on" position.
โNov-20-2017 11:51 AM
Bud
USAF Retired
Pace Arrow
โNov-20-2017 10:48 AM
โNov-20-2017 10:43 AM
Old-Biscuit wrote:
Correct wiring is:
Brown (12V DC from On/Off Switch)-----to/thru thermal fuse----to/thru T-stat---to TOP Connector on Control Board
- (2nd space on connector empty)
Blue (12V DC from Control Board to Fault Light)
Red (12V DC from Control Board to/thru ECO ---to Gas Valve Solenoids to GRD (Both solenoids have to energize for gas valve to open/flow propane)
- (5th space on connector empty)
Green (12V DC Neg/Ground)
Spark Electrode High Tension Wire connects to 'voltage transformer' on Control Board....sends 2000V to Spark Electrode to ignite propane
Gas Valve only has power to solenoids for 6-8 seconds WHILE spark electrode fires.
Trace the DC Path
On/OFF switch ---Brown wire to control board, then Red wire to gas valve
If you have 12V DC all the way to/thru gas valve solenoids then you should be able to 'manually' light the propane using a BBQ lighter.
Where are you placing Brown wire to get Spark but no propane??
โNov-20-2017 08:43 AM
โNov-19-2017 06:01 PM
enblethen wrote:
Lock out comes on because it didn't fire.
Your new board is odd and should have come with instruction sheet or label on this Universal board.
โNov-19-2017 05:49 PM
Bud
USAF Retired
Pace Arrow
โNov-19-2017 05:47 PM
โNov-19-2017 05:28 PM
โNov-19-2017 05:13 PM
Bud
USAF Retired
Pace Arrow
โNov-19-2017 05:02 PM
Bud
USAF Retired
Pace Arrow
โNov-19-2017 04:39 PM
enblethen wrote:
Make sure the electrode is adjust to about 1/8 inch from ground probe.
โNov-19-2017 04:28 PM
Bud
USAF Retired
Pace Arrow
