I installed the new water/fuel separator filter and made sure the old gasket on the thread end was removed and new gasket installed. Filled up the new filter with fuel making sure to plug the center hole. installed the new fuel filter and started it up and test drove it.
It now it has Very low power when accelerating, it shakes but very low acceleration power.
I also installed a new air filter.
What could be wrong, It ran great up until I changed the water/fuel filter. This is on a Cat 3126E (HEP20882) with only (1) fuel/water separator.
I have now installed a total of 3 new filters with the same results. using the following filters Cat 1752949, Baldwin BF1268 and now Wix 33783 w/bowl.
Freightliner said the original filter was Racor 3203 (Alliance ABPN12232FRT03)
Totally confused. What do I need to try now.
