Converter breaker labelling
rjsurfer
When I'm running my air conditioner unit from the generator I turn off the converter breaker to keep the load down but that breaker is labelled rec/conv what the heck does rec mean?
Ron W.
03 Dodge 2500 SRW,SB,EC
2018 Keystone 25RES
DRZ-400SM
DL-650
12 REPLIES 12
LarryJM
Your question brings up IMO an important point for both CBs and 12 fuzes and that is one should make sure they understand "EXACTLY" what each CB and each fuze protects and make a list now before you have a problem. This should have every 110V and 12V light, appliance, item that uses either 12 or 110 v power. This is critical when one item goes out since that way you can trace where the issue might be.l I keep a copy of my list taped inside the converter power cover so I know where it's at when and if needed.
P.S. don't forget to include the actual ground fault items since some outlets on that might be there more from convenience than actually being required by code.
Larry
2001 standard box 7.3L E-350 PSD Van with 4.10 rear and 2007 Holiday Rambler Aluma-Lite 8306S Been RV'ing since 1974.
RAINKAP INSTALL////ETERNABOND INSTALL
rjsurfer
ScottG wrote:
Unless you have a bunch of lights on or your battery is low, the converter isn't much of a load.
Agreed, but I'm right on the bleeding edge of running the air conditioner safely.
I like to keep the a/c volts above 115 to protect the compressor motor and it will dip below on occasion with rec/conv breaker on.
Thanks
Ron W.
2018 Keystone 25RES
DRZ-400SM
DL-650
john_bet
My 5th has a stand alone conv. plugged into a rec. It is the only thing on that circuit.
2018 Ram 3500 SRW CC LB 6.7L Cummins Auto 3.42 gears
2018 Grand Design 337RLS
ScottG
BFL13
The Parallax 7355 often has one circuit breaker the converter and receptacles share. In ours that includes GFCI ones. Also the 120v lights.
Also includes the receptacle the fridge 120v plugs into outside, so the procedure to turn off the converter to run the air conditioner might make the fridge switch to propane. (It probably is anyway in this scenario to save generator load)
With no converter on, 12v must come from battery to run the controls for the thermostat, fridge, etc.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
mbopp
I had a compatible breaker and spare slot, so I put the converter on its own breaker.
2019 F250 XLT Supercab
Just DW & me......
rjsurfer
Op back, you guys are right its something outlet related because I remember once after flipping the breaker my wife mentioned that something shut off. Forgot about going back and checking it out.
I'll be going back to the camper tomorrow and check them all out.
Ron W
2018 Keystone 25RES
DRZ-400SM
DL-650
RoyB
Some converter/chargers come with a 120VAC PLUG. My PD9260C has this...
I would guess that is what REC stands for... My 5th wheel is labeled CONV and I suspect in most trailers this will end up being the second circuit breaker down the panel with the MAIN Circuit breaker being the first. The MAIN and CONV is stamped on in INK. All the rest is penciled in...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
time2roll
Take an outlet tester around and see what is off.
Probably non-GFCI linked outlets.
MrWizard
Moderator
Moderator
Moved from technology corner
I can explain it to you.
1997 F53 Bounder 36s
Old-Biscuit
Your panel was labeled :B
Chris_Bryant
Receptacle- some outlet will be on this breaker, as well.
-- Chris Bryant
