Converter/charger and auto resetable circuit breaker
markbrown47
I just replaced my Wfco for a Boondocker converter/charger. My trailer came with a 40a breaker In between the charger and battery. The Wfco was a 55a charger, the Boondocker is a 60a charger. Will the 40a breaker affect the 60a Boondocker charger? I get 13.5 volts on the charger side of the breaker and only 12.4 volts on the battery side. I am going to replace the breaker. Should I go back with a 40a or a 60a?
1999 F250 4X4
Firstone Air Bags
Delorme Topo 10
2006 Keystone Challanger 34RBH
4 REPLIES 4
pianotuna
Nomad II
Nomad II
Hi,
Fuse to the wire size, always.
Regards, Don
markbrown47
Thanks will double check the wiring size and change to a 60a breaker. If I have to I will be pulling new wires.
1999 F250 4X4
Firstone Air Bags
Delorme Topo 10
ScottG
Yes, the breaker will trip repeatedly until the battery charges enough that the current is lowered . I would replace the breaker with a bigger one if the wire size can take the current.
BFL13
The wiring from converter to battery may be too long and thin to get you all 60 amps when charging a low battery, but it might not be that long and thin, so IMO go for the 60amp breaker.
At least you should get more than 40a.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
