converter fan noise
old_guy
can you replace fan in converters? mine is making a noise like the bearing are going out.
6 REPLIES 6
Shadow_Catcher
Stick a meter on it and find out, there are AC fans of about any description. Best bet do your yourself a favor and change it over to a Progressive Dynamics. I have yet to hear the fan in ours.
ksg5000
Not sure but I think the old Magnatek fans are AC vs DC based - if so the std computer fan won't work. In my case I found cleaning/oiling was only temporary solution.
Kevin
RJsfishin
Never found a bearing yet that I couldn't get some oil in, even if it means drilling a hole. Question is, is it worth the trouble ? And trouble is, every time I've done it, it was short lived.
If its wore out its probably an old single stage ?? Deep six it !
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
westend
You might try cleaning the fan blades and lubricating the fan bearing. I've had more than one fan recovered by doing this and the cost is low.
'03 F-250 4x4 CC
time2roll
Not without removing the old. Go for it. Worst case get a new converter.
Second_Chance
My guess is, "Yes." They are very much like the fans in computer power supplies. You would just have to disconnect both shore and battery power, pull the cover off the converter, get the specs off the fan, and see if you can find a replacement. If you have to order one, you would have to put everything back together and put up with the noise until the new one arrives.
Rob
U.S. Army retired
2020 Solitude 310GK-R
MORryde IS, disc brakes, solar, DP windows
(Previously in a Reflection 337RLS)
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
