โMay-29-2013 10:15 AM
โDec-02-2013 01:51 PM
โDec-02-2013 01:40 PM
โDec-02-2013 01:14 PM
DryCamper11 wrote:BFL13 wrote:
Interesting about the way the "mass" part of the thermistor works.
So what is the implication between these two, which are both 5R but 20a and 25a where both those amps are well above steady state 13a. The obvious difference is in the greater mass of the MS35, but would that be better? (I have managed to blow both types with hot restarts)
http://www.ametherm.com/datasheetspdf/MS355R025.pdf
http://www.ametherm.com/datasheetspdf/SL325R020.pdf
The MS35 5R025 is wider and thicker. Yes, it has the same resistance, but it can handle 600 Joules instead of 200. Note that the capacitance numbers are also exactly 3 times greater. They get the same resistance, but higher energy/capacitance numbers by using different semiconductor material so the net junction volume is greater, but the net resistance is the same. More junction volume with the same energy dissipated means less heating per junction region and less damage, so the ratings can be higher.
I don't know if I answered the question you asked, but it was my best shot. ๐
โDec-02-2013 12:33 PM
DryCamper11 wrote:Salvo wrote:
Yes, we're only talking about the actual thermistor, not the adjacent material. It has a large time constant. Take a look here.
I'm not sure why you're pointing to a bead thermistor. They are used for measuring temperature, not for controlling current inrush.
I once designed and built a device that measured how fast an elevator was rising/falling. It used two tiny bead thermistors in a tube connected to a thermos bottle. As the bottle went up/down in the elevator, air would flow in/out of the tube to fill or exit the bottle. The bead thermistors were positioned in line so that one or the other would be cooled more than the one behind as air pressure change due to elevation change caused air to flow into the bottle (elevator down) or air to leave the bottle (elevator up). A differential amp with a bridge circuit allowed measurements of only a few feet per second of elevator speed.Encased thermistors have 2.5 s max time constant. ....
I've provided a link showing thermistor time constant is max 2.5s.....
You're still looking at time constant for the entire thermistor. That's not what's relevant. It's the time constant for heat to leave the semiconductor active region and flow into the bulk semiconductor material on either side thereof. We're talking micron size regions and heat flow distances. That has little or nothing to do with the quoted time constant of the bulk device. That time constant is factored into the Joule rating and the capacitance rating of the device. It isn't specified directly.
The capacitance rating and the voltage set the Joules that the device is able to absorb. That energy appears as heat in the active region of the semiconductor junction. It will move from those hot spots in milliseconds. If the heat isn't allowed the millisecond(s) time it takes to diffuse away from that region, it is damaged and the device fails.
The device time constant that is specified in the ratings is different. That number is used to determine how long it takes before the device has heated to the low resistance value (or recovered to the high resistance value specified at zero power after power is removed.) That time constant has nothing to do with the surge ratings.
โDec-02-2013 12:30 PM
โDec-02-2013 12:13 PM
BFL13 wrote:
I got lost with the thermistor/filter capacitor relationship. Is the MS355R025 superior for that compared with the SL325R020, where I have 2400uF of capacitors?
It was mentioned there is a minimum thermistor spec wrt the capacitors, but if both are above minimum does it matter which is used?Not really. One will cost less and the other will be stressed less.
โDec-02-2013 11:14 AM
DryCamper11 wrote:The thermistor has no time to cool down during the transient.
It's not the entire thermistor that cools down. It is the tiny active region(s) that must transfer heat from that region into the adjacent material. That transfer has a time constant that is much much less than the bulk time constant of the entire device. You can damage the thermistor without producing significant heating of the entire device if enough current is passed through it in a short time.
Encased thermistors have 2.5 s max time constant. The transient is only 4 ms. There is no cooling during the transient. It doesn't matter if you got a 1 ohm or 10 ohm thermistor, both will get to the same temperature following a turn-on transient.That means your argument is not correct. Resistance has no effect on how hot the device gets during the transient.
We disagree. The resistance of the thermistor controls how much heat (energy=1/2 CV**2) is dissipated in the semiconductor active region(s) of the thermistor per unit time. Given the small size of the semiconductor region, the total energy dissipated as heat has sufficient time to diffuse out of that region before the region is damaged even though the entire device does not have time to cool significantly.
Again, I've provided a link showing thermistor time constant is max 2.5s. The greater the thermistor thermal capacity, the greater the time constant. That's something I was eluding to quite a few pages ago. The big capacity thermistors do not respond fast enough in lowering their resistance. 2.5s is an eternity when the converter is up and running drawing 13A. This is the time when we see the tremendous heat stress. The greater the thermistor resistance the greater the stress.Resistance does have an effect on steady state use. The greater the resistance the hotter the device gets.
No, the greater the resistance, the longer the time it takes to dissipate the 1/2 CV**2 energy (during the initial charge cycle of the capacitor). Power is energy divided by time, and the energy remains constant, while increasing resistance increases the time over which that energy must be dissipated.
You're not reading my comment correctly. I'm not talking about turn-on, but rather steady state operation. The converter is drawing 13A continuous.
In steady state, we are no longer interested in the initial (zero power) resistance - we are interested in the steady state resistance, which is close to zero.
The thermistor resistance gets close to zero after one time constant. Until then, there's some major cooking going on.
Sal
โDec-02-2013 11:09 AM
โDec-02-2013 10:44 AM
โDec-02-2013 10:29 AM
โDec-02-2013 10:15 AM
โDec-02-2013 10:13 AM
Salvo wrote:
You are dealing with a thermal transient during turn-on.
The pulse of the transient is much smaller than the thermal time constant of the thermistor.
The 5 ohm device will always be hotter than the 2 ohm device.
โDec-02-2013 10:10 AM
โDec-02-2013 10:08 AM
LScamper wrote:
ken white wrote:
"The volt-second relationship is only valid for continuous current flow during steady state.
If you exceed the kVA rating, with a large impulse current, then my guess is the core will saturate - it is being operated outside of design specifications... "
First, I left out that core saturation is due to not enough magnetizing inductance that keeps the unloaded current down. It has nothing to do with load current.
If you exceed the kVA rating with a large impulse current you may melt the windings but you will not saturate the core if you have enough V-S!
I spent 35+ years in pulse-power. I have designed hundreds of high voltage pulse transformers. V-S is the king, VS=NBA. Current is not involved with core saturation.
โDec-02-2013 10:02 AM
