โNov-22-2020 11:28 AM
โDec-05-2020 05:18 PM
โDec-05-2020 05:04 PM
โNov-30-2020 04:33 PM
โNov-24-2020 01:18 PM
โNov-24-2020 12:42 PM
โNov-24-2020 12:30 PM
โNov-24-2020 11:48 AM
BFL13 wrote:2112 wrote:
WOW that IOTA is a deal. I grabbed 1 to replace my WFCO junk. 30A is all I need.
The IQ4 upgrade is $20 on Amazon
Thanks for sharing
There was an Iota about 12 years ago ( ISTR it was in Jaycos) that did not have the jack hole (whatever that is called) for the IQ4 (which used/uses the same jack hole for the booster jack they had.)
So be sure this one has the place to plug in the jack if you want an IQ4 to go with it. They have a new range of IQ4s now, for different charging profiles you can choose from.
โNov-24-2020 11:04 AM
Thanks for sharing
โNov-24-2020 10:30 AM
โNov-24-2020 07:25 AM
โNov-24-2020 05:16 AM
โNov-24-2020 02:37 AM
CA Traveler wrote:
The function of a charger is to charge and maintain the battery and wire loss is also a factor. The charger therefore should be close to the batteries or be connected with larger wire.
โNov-24-2020 01:43 AM
โNov-23-2020 06:55 PM
โNov-23-2020 04:47 PM
