โFeb-20-2021 09:13 AM
โFeb-23-2021 06:44 AM
โFeb-23-2021 06:29 AM
BFL13 wrote:While I agree that the break away switch should be an unfused run from the trailer battery, (and mine now is), my trailer came with the break away switch connected to pin 4 of the 7 pin connector. Maybe this is allowed in Canada?
Keeping the charger to house battery wires short will help preserve the charger's voltage settings for each type of battery as instructed in the manual for using the dip switches.
Voltage variations on the longer run from the unit to the starter batt should be taken care of by the unit's buck/boost as I understand it.
You could make the unit portable by using MC4s on its input and output wires?
EDIT--the breakaway on a trailer puts the trailer's brakes on right from the trailer's batt (not to be fused), nothing to do with the 7-pin.
โFeb-23-2021 06:11 AM
โFeb-23-2021 05:02 AM
โFeb-22-2021 06:16 AM
โFeb-22-2021 04:55 AM
BFL13 wrote:
Is everyone getting one of these things? ๐
It says to put the unit as close to the house batteries as possible. Makes it tricky for using with a trailer or truck camper and have fat wiring to the truck.
Not clear to me, but they want to reduce voltage drop between unit and starter batt, but want the unit closer to the house batts. So longer wires will be from unit to starter batt, but they will need to carry the higher input amps. Maybe putting the unit closer to the starter batt makes more sense? Guess it depends on your set-up and what your voltmeter tells you once you try it out.
โFeb-21-2021 02:26 PM
โFeb-21-2021 02:07 PM
โFeb-21-2021 01:29 PM
BFL13 wrote:
As is, the truck and camper batts are in parallel with the 7-pin connected whether or not the ignition is on. I left the 7-pin connected for the signal lights etc, but disconnected the charge line so now no "alternator charging".
โFeb-21-2021 12:59 PM
pianotuna wrote:
BFL13,
The 7th pin may back feed from the trailer when the engine is running. I don't think that is too productive for presenting 14.7 to the house batteries. A simple dc rated switch on the 7th pin feed wire would solve the issue.
โFeb-21-2021 12:25 PM
โFeb-21-2021 10:35 AM
โFeb-21-2021 10:00 AM
BFL13 wrote:
I like the always live 7-pin on my Chev. When the camper is on, and parked for a long time, the shore power to the camper converter floating the camper batts also floats the truck batt.
With the 5er it was not an issue since the 7-pin is disconnected when you un-hitch and move the truck away.
Without that, I need another maintenance charger for the truck batt. I have to use a second charger for the Ford Class C to keep the engine batt up when parked a long time.
Since I don't want to mix batt types now, I have to use a separate charger for the truck batt anyway. With the Renogy installed there is no choice, so separate charger for the truck still needed.
