โOct-06-2015 04:46 PM
โOct-08-2015 01:54 PM
enblethen wrote:
BFL is a poster here on rv.net
โOct-08-2015 01:38 PM
Bud
USAF Retired
Pace Arrow
โOct-08-2015 12:48 PM
D.E.Bishop wrote:
There are three Harbor Freight stores within a 10 or 20 mile radius of downtown Fresno. For less than $10 you can buy an inexpensive meter(DMM, item 98025) and check voltages. It is easy, plug the red lead into the socket marked V, Omega, mA, the black into COM, turn dial to ACV/200, turn the meter on, you are all set to go. With the distribution panel removed, touch the black lead to the common buss(white wires)and red lead to the colored wire set screw on the converter circuit breaker. If you get 120 on the meter go to DCV/20 and test the DC wires to the battery. All the things are easy once you learn a little bit about the panel.
If you aren't sure of your understanding of where to touch the leads, ask around the campground, the office is a good place to start. Someone will help you and you'll be able to do it by yourself soon.
โOct-08-2015 12:47 PM
MEXICOWANDERER wrote:
What's alien about getting an automatic charger like BFL uses and use that to tide over until an electrician and converter can be saved up for? Even a 65 dollar Megawatt set to 13.6 volts would provide plenty of power. Have an electrician connect a power cable and a couple of 10-gauge battery clips over the counter.
โOct-08-2015 12:04 PM
โOct-08-2015 11:35 AM
โOct-08-2015 11:22 AM
โOct-08-2015 11:18 AM
mkirsch wrote:
Put the charger back on the battery. All you're doing by watching and waiting is running down your expensive new battery and ruining it. Keep it charged. The converter is not going to magically start working again.
mkirsch wrote:
You really need to get somebody in there to look at it. The hard part will be finding someone that's qualified to make a house call. Check with a nearby RV dealer.
I really really really don't think you should try replacing the converter yourself. It's going to be nigh on impossible to talk you through it on this forum, and you don't have the experience yet to go it alone. Make a mistake and you could damage the trailer's electrical system, or worse, burn it down, leaving you homeless.
This is important. You really need to find someone that knows what they're doing, not someone who will do it cheap/free because they think they can. With the alternatives being some temporary financial hardship, or homelessness, I would take the financial hardship.
โOct-08-2015 11:05 AM
Byrogie wrote:
Annie, have you asked your neighbors. There should be at least one guy living in the park that could at least help you troubleshoot the problem??
โOct-08-2015 07:55 AM
โOct-08-2015 07:44 AM
โOct-08-2015 07:35 AM
AnnieL wrote:
Hi, I did check in to a meter at the local hardware store but they want $22.00. I am one hour from the Walmart. I have one I can borrow...just the guy isn't there right now.
I don't know what I'm supposed to buy...I went to this one and it $197.00.... http://www.bestconverter.com/45-Amp-Converter-Replacement-Kit_p_46.html#.VhWq-7T-_FI
โOct-07-2015 08:44 PM
โOct-07-2015 04:49 PM
Bud
USAF Retired
Pace Arrow
