โFeb-01-2014 08:54 AM
โFeb-01-2014 02:15 PM
MEXICOWANDERER wrote:
"My inexpensive Schumacker charger does not seem to be working. I can hear it running but if I put the pos. & neg. clips from my volt meter on the battery terminals I get zero reading. Is this how you check a charger?
Thanks"
I merely responded to the question not a permutation. Ten Thousand Excuse Me's...
โFeb-01-2014 01:22 PM
โFeb-01-2014 01:11 PM
I thought you were measuring CHARGING voltage or at the least CHARGING amperage.
What voltage do you have AT THE CHARGER when it is plugged-in and switched on?
โFeb-01-2014 12:30 PM
โFeb-01-2014 12:24 PM
Weldon wrote:
I put the charger on a 12v 6 amp battery for a game camera, left it on for a couple of hours. There was zero improvement in the batteries voltage after the charge.
Thanks for the comments!
โFeb-01-2014 11:27 AM
โFeb-01-2014 11:06 AM
โFeb-01-2014 10:24 AM
Weldon wrote:Ok. A zero reading at the batteries is highly unusual. There's usually something left. Perhaps the batteries are stone dry.
Yes the volt meter is set correctly....
โFeb-01-2014 10:09 AM
Thanks
โFeb-01-2014 10:05 AM
โFeb-01-2014 09:55 AM
โFeb-01-2014 09:40 AM
โFeb-01-2014 09:35 AM
