dirt devil power head
DIVE2XS
I have a dirt devil central vacuum cleaner in my TT. The original head that was air driven. It just didn't pick up good.
I have noticed that there are power heads that are powered electrically.
It doesn't look like its powered by 110 volts...it takes lowered voltage.
I have a 110 outlet net to where I connect the hose to the system.
Is there a way to adapt to it or do I need to buy a whole new system?
I haven't been able to find one from dirt devil. The trick is to find one small enough to fit in the same space.
Thanks!
2001 Suburban,8.1L engine, 4.10 rear end
2003 Holiday Rambler Presidental 32'
2 Honda 2000i generators
100 watt solar
Podogy Controler
0 REPLIES 0
